What kind of oil should I use... blown, summer car...
Old May 22, 2003 | 08:35 PM
96 WS6's Avatar
I usually use 5w30, should I move up to 10???
Old May 22, 2003 | 09:21 PM
got_hp?'s Avatar
i use nothing but Shell Rotella 15w40 Multigrade.
its mostly used by big turbo diesel mack trucks (if it can stand up to that abuse, its fine for my car!). it was also recommended by turbo engineers at KKK and garrett.
Old May 22, 2003 | 09:34 PM
94SLUG's Avatar
I use this in all diesel trucks, but there is hella detergent in diesel oil, because of the hudge build up from a dirty runing motor. I would not use Rotella unless you want to clean a internaly dirty engine. The break down rate is much less but i would never use it in my car for over a hour. Pull the dip stick when you put that in a semi dirty engine and the oil will turns black in one day. Its not made for a gas engine. The only time i use this is on high milage trucks that need a little cleaning. How long have you been runing it?
Im using Mob synthetic and like heavy oil in summer time(south florida)! I change it every 1000 miles anyway kind of **** about oil.
EDIT: Ahh yes your from Florida too.
Old May 23, 2003 | 11:46 AM
got_hp?'s Avatar
hmm...........ive been running it about 9 months now (put on 17000 in that time). my car doesnt burn/leak one drop, my oil pressure is always perfect, and it runs like a clock. i change oil and filter every 2500 or so.
it says that its full compatible with all regular gas engines........but you dont think its a good idea?
Old May 23, 2003 | 01:16 PM
94SLUG's Avatar
Well I just dont think its a good idea, but you have had no problems in 9months so..... In diesel grade oil the viscosity break down is not the same as gas oil. One other thing to think about is the RPMs a diesel motor runs at(600-3000 MAX), and they hold 16crts of oil. Like i said before its great oil and the only oil i would put in a Cummings/Powerstroke not a race engine.
Old May 23, 2003 | 04:01 PM
got_hp?'s Avatar
thanks for the input..............i guess ill have to take a look at other oils.
btw, i ran this oil on my previous car, a 3000gt twin turbo, and it solved my problem of "ticking" lifters. but i didnt keep the car long-term, so im not sure how it held up.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
