What # injectors do I need?
Old Jul 31, 2006 | 10:22 AM
stevencmt_z-28's Avatar
I have a 96' camaro lt1. It has been punched out to a 355ci with port and polished heads. It is also running a powerdyne supercharger @ 6psi. Other than that just the usuall bolt-ons. My question is I need to replace my injectors and was wondering what # would be best?
Old Jul 31, 2006 | 10:25 AM
cjmatt's Avatar
Re: What # injectors do I need?
i ran 30s with my powerdyne and had no problems. theyre for sale if youre interested.
Old Jul 31, 2006 | 10:40 AM
How does the Powerdyne add the extra fuel when its under boost... with an FMU that raises the fuel pressure, or using the stock fuel pressure and PCM 1bar+ programming? That will determine the required injector size.
You might want to consider posting a question like this on the Forced Induction forum..... I'll move it there for you.
Old Jul 31, 2006 | 11:25 AM
jonota's Avatar
I would say that mostly depends on where you want to go with the car. The stockers are definitely not up to the task for much more power than you have now. 42# seems to be a popular choice with the forced induction crowd. Anywhere from 36-70 seems to be available, the more power you want eventually the bigger you should go. You CAN have too big of injectors for you system though.
Jonota
Old Jul 31, 2006 | 11:37 AM
RealQuick's Avatar
I would say atleast 42's...
Old Aug 6, 2006 | 10:37 AM
CALL911's Avatar
If you plan on leaving the boost level the same I would say 42's would be ideal.
I have 60#ers in my 95, 383, D1SC with 15#'s of boost.
Old Aug 6, 2006 | 11:53 AM
joe-96z1le's Avatar
I agree w/ Injuneer. Do you have an FMU? Or are you running a custom tune? With an FMU
and an auxiliary pump 24's are enough.
Old Aug 9, 2006 | 07:59 PM
LT1-TA's Avatar
you can get the ford 42# injectors for less than $300 brand new from jegs..
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
