What IATs are you guys seeing?
Old 09-20-2004, 12:56 PM
slimdawson's Avatar
I haven't done a full pass yet but I was playing around last night and notice that my IATs pick up about 5-7 degrees if I watch them in 4th gear to redline. Outside temp was around 65. That is at 8lbs and a front mount ATI intercooler. I think I have the smallest intercooler ATI makes How much increase should I expect? It seems to be doing a good job so far.
List the amount of boost you are running as well as intercooler size if you can.
Thanks.
slimdawson is offline
Old 09-20-2004, 11:03 PM
sleeperz28's Avatar
Re: What IATs are you guys seeing?
At 24#'s of boost IAT's increases about 20 degrees by the time a 1/4 pass is over. Front mount intercooler
sleeperz28 is offline
Old 09-21-2004, 12:25 AM
Highlander's Avatar
at 24# of boost that is very LITTLE increase in IATs!!!! what is the CFM rating of your intercooler and how big is it?
I sure hope this is enough for my setup... for just 12psi...
http://cartechpr.com/forums/uploads/CarPics046b.jpg
Highlander is offline
Old 09-21-2004, 09:17 AM
Sneakin Deacon's Avatar
hmm, i have a V1 S-trim on 8psi and see 145* intake temps on average cruising...after a hard hard maybe 3-4-5 run itll be in the 160 range...not intercooled btw. will be doing an alky kit soon.
Sneakin Deacon is offline
Old 09-21-2004, 09:50 AM
slimdawson's Avatar
Even though I have no idea, 145 at cruising seems high. When I was cruising yesterday, my temps were 79 degrees with an outside temp of around 72.
Old 09-21-2004, 10:00 AM
Ucantcme57's Avatar
Is that an Air to Water Intercooler? Where did you get it? What are it's dimensions? Info like this would be very beneficial..
Ucantcme57 is offline
Old 09-21-2004, 10:02 AM
Ucantcme57's Avatar
Is that an Air to water Intercooler? Where id you get it? What are it's dimensions.. Info like this would be very beneficial..
Old 09-21-2004, 03:26 PM
SMOKNZ's Avatar
The only 2 logs I have show temps rising from ~30deg's to 35degs going from a 30 mph roll to 110 or so. Temps in deg's C. Was only at 7 psi. The core is a 8" x 24" x 2.75" Front mounted air to air with lots of airflow!! The deg C to F converter shows 86 to 95 degs during the run. Not to bad!
Bill
SMOKNZ is offline
Old 09-21-2004, 07:28 PM
5.0THIS's Avatar
He said it was a front mount intercooler, so I'd say it's an air to air unit.
5.0THIS is offline
Old 09-21-2004, 07:33 PM
Highlander's Avatar
I have Front mount and its NOT an a2a
Old 09-21-2004, 07:52 PM
SMOKNZ's Avatar
I believe SleeperZ28's intercooler is water to air. Just happens to be in the front. I bought his air to air years ago (and since sold it) and he converted to air to water and probably still has it.
SMOKNZ is offline
Old 09-21-2004, 09:20 PM
INTMD8's Avatar
Location: I reached back like a pimp and smacked that LS1....
At 23psi going through the traps at the top of 4th gear, IAT's are at 188 degrees on an 80 degree day.
Two intercoolers, with core dimensions 15in wide 6in tall 4.2in thick (top/bottom flow).
I have no ducting to the intercoolers. I plan to try that first, and if IATs are still too high I'll convert to air/water.
INTMD8 is offline
Old 09-22-2004, 12:48 AM
5.0THIS's Avatar
Fair enough, but most people mean air to air when they say front mount.... I guess unless he was refering to where he mounted his heat exchanger, or the cooler itself...
5.0THIS is offline
Old 09-22-2004, 08:48 AM
Geoff Chadwick's Avatar
Why did you use a core that was so thin? Looks like it's 3" thick or so (rough guess)- with that big an air/water, why not go with a 4.5" thick or 6" thick?
I'm looking at an air/water core that's 21"x4.5" and 5.5" thick... and that should keep me moving through 12psi... If not, I'm spraying methanol as well, and I'll have a few gallons of water moving through the heat exchanger.
Geoff Chadwick is offline
Old 09-22-2004, 09:36 AM
carnutz's Avatar
I am 90% sure its not, it is a A2A that he got off of a old supra race car. At least thats what he told me about a month a go.
carnutz is offline
Quick Reply: What IATs are you guys seeing?
