what fuel injector size should i use?
Old Apr 11, 2004 | 09:50 PM
xtremetrans's Avatar
I have a 8psi dual intercooled 1995 LT1 camaro with stock engine. I have heard you can get rid of the FMU by adding 42# injectors. Is that a good idea? and what should my fuel press. be? What other mods should I do with my supercharger?
Old Apr 11, 2004 | 10:24 PM
lt1ownsall's Avatar
42s will wotrk just fine at 42psi
Old Apr 12, 2004 | 07:37 AM
LWM's Avatar
LWM
If you go to SVO aka Ford Motorsports 42# injectors you will need to tune your set up. I recommend LT1 editor and/or Tunercat, the editor is what I use and it works great. I haven't heard anything bad about Tunercat.
FWIW, I run my 42# SVO injectors at 49psi, vacuum disconnected, and in the LT1 editor I rate the injectors as 47.5#. Thing runs like stock, but is a bit rich and ugly on a cold start.
You will also need a session on the wide band dyno to fine tune your set up.
What other mods ?? Sub Frames and Headers ... in that order.
Hope this helps
LWM
Old Apr 12, 2004 | 09:03 PM
JZ 97 SS 1500's Avatar
42's or 50's are fine.
Jose
Old Apr 13, 2004 | 10:01 AM
carnutz's Avatar
LWM
If you are tuning it cant you pull some fuel out in the cold start tables? to clean up the cold start richness?
Old Apr 13, 2004 | 12:04 PM
LWM's Avatar
LWM
I'm using the LT1 editor and I don't know where that table is. I have found an air/fuel ratio VS temperature table that I have leaned out a bit in the cold temperatures, but I haven't found anything that will decrease the amount of fuel it gets while cranking.
If you know how to do this in LT1 editor ... I'm all ears
thx
LWM
Old Apr 13, 2004 | 09:41 PM
Is a hot cam ok for my car?
AdsoYo
May 2, 2018 03:21 AM
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
