What do you think of this setup, will it work?
Basicly I'm just looking to see if this will be dangerous, the setup I have in my sig plus a blower? I know I know, the cam/compression is not right, but compression I counted it up to be 10.9:1 & yes big cam on 112lsa. But what is the safe as far as boost goes? Basicly I want to just give it a little more top end power & most importantely more drivability, can I do this with a blower? LIke can I go like 3lbs of boost or something? LMK guys & what you think.
This is 100% serious.
Re: What do you think of this setup, will it work?
I agree that something like a 50hp shot would be more suited to your setup. The high compression will love the nitrous and would make a blower problematic.
If you really like the idea of having the power on tap that the blower provides, look at 6-8lbs of boost and use alky/water injection to help limit detonation. You can get more on the injection stuff reading the Buick turbo boards...
Keep in mind that altitude has a lot to do with how much you have to worry about boost. If you're at 5000 ft., the 6lbs wouldn't be a problem... JMO.
Hold on to it until your rebuild and then go with dished, forged pistons and strength the bottom end.
or
Pull the heads and hog out the chambers to 62cc-64cc to lower compression. Then use the alky/water injection.
or
Put it in the for sale section and buy a 50 shot...
or
Go ahead and put it on and when you fry a piston go back to the first option on this list...
or
or
or
Lt1son
Dec 31, 2014 01:35 PM
so hmm... so what if you had a blower laying around?
