What do you pay for VP C 16
Old Feb 15, 2004 | 12:03 PM
sleeperz28's Avatar
Im getting ready to put a order in for a drum of c 16. Its about $380-390 a drum. What do the rest of you pay?
Old Feb 15, 2004 | 12:07 PM
rskrause's Avatar
Moderator
Re: What do you pay for VP C 16
That's less than it is here
Rich Krause
Old Feb 15, 2004 | 03:34 PM
Mochanic's Avatar
$5.35 a gallon no matter how much you buy. so $295 for a 55 gallon drum. Only because we have an account with them.
Old Feb 15, 2004 | 07:29 PM
RacinLT1's Avatar
we pay right around 5.50 or so a gallon.
it's good to live within a few minutes of VP east coast distribution center.
Old Feb 15, 2004 | 09:16 PM
Jids's Avatar
its about $8.50 canadian per gallon here I think......
Old Feb 16, 2004 | 07:56 AM
IDOXLR8's Avatar
Must be cheaper because you have an account with them. Here in MI you will pay close to $9.00 a gallon.
Old Feb 16, 2004 | 11:14 AM
Birdie2000's Avatar
Wow, maybe I should rethink my desired fuel choice.
Old Feb 16, 2004 | 11:48 AM
Pro Stock John's Avatar
It's like $8.00 a gallon up here from ASSC.
Old Feb 16, 2004 | 12:15 PM
IDOXLR8's Avatar
Did you ever get your car running right?
Old Feb 16, 2004 | 02:56 PM
Birdie2000's Avatar
We're in the process of it right now.
One thing that we found was contributing to the high boost levels was the fact that the intake manifold gasket was covering a good part of the ports because it was installed improperly. Also discovered that the valves needed a fair amount of machine work, as the valve job was pretty poor. Other than that, the engine is tore down to a shortblock and everything is in pristine condition. Hoping to make more power through the cam and head/intake manifold porting, along with a new tune with some better gas.
Old Feb 18, 2004 | 09:31 AM
I'm using VP C12 which is less than $6 a gallon, my frontmount intercooler is working great.
Old Feb 18, 2004 | 09:52 AM
sleeperz28's Avatar
Jess tells me you picked up his edis box, hope it works out well 4 ya. You plan on running the cam sensor in the rear? Thats pretty much the best way to do it to avoid problems.
Old Feb 18, 2004 | 10:03 AM
Jake, I am not sure on the cam sensor, I believe it's straightforward to use the factory LS1 cam sensor with the FAST but I will have to doublecheck.
FAST is coming out with an LS1 crank relay box so I can go FAST standalone and remove my factory harness and pcm, which I am still using to control timing but not fuel.
Formula Steve
Sep 19, 2023 08:31 AM
G-BODYT56
Jan 14, 2022 11:14 PM
RX Speed Works
Oct 1, 2015 10:19 PM
Sep 18, 2015 03:46 PM
Aug 28, 2015 07:53 AM
