What do we think about Flatout head gaskets?
Old Apr 14, 2009 | 12:34 PM
jsetzer's Avatar
I've done my reading on copper. I hate our search engine - I haven't found much info on the flatout gaskets. Rubber coated copper. Rubber seals for the water/oil passages.
Either these or the felpro mls.
I know head gaskets usually pop for a reason - I could have been lifting the heads, or it could have been detonation. Plugs don't show any at all. I don't use a knock sensor though.
Should I switch to studs? Its just more money at this point. (ARP bolts right now)
Old Apr 14, 2009 | 01:16 PM
S M R's Avatar
I have Flatout rubber coated copper on mine and no problems so far. Seen 17psi max so far and no leaks, seeps or anything else.
I have ARP studs and my block is o-ringed though.
I would switch to studs for sure.
Old Apr 14, 2009 | 02:07 PM
jsetzer's Avatar
Well the o-rings are only the around the cylinders right? I could always take that step too, but don't think I am making enough power for it.
Your 17psi is a lot more than my 17 psi
I'm more worried about water leaking so they sound good to me. Thanks!
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
