What to do? Switch oil pump or pan?
I have been reading that an HV oil pump will suck a stock oil pan dry. Well I have a stock oil pan and was going to put a HV oil pump on. Should I get a canton oil pan, or ditch the hv oil pump and get the melling select oil pump,and gm hp white spring. and stick with the stock oil pan...? This is going on a built 355, with a front mount t76 (realquicks hot parts)
Slowest build #2
Slowest build #2
2 bolt or 4 bolt splayed main caps?
I had to do some modification to my stock pan around the dipstick/windage tray to make it work with 4bolt caps w/ studs and stroker crank etc. I'm using the Melling Select 10554 and a white GM spring with my factory oil pan.
Slowest build #2
Slowest build #2
6 years stock pan HV pump...
