At what boost level is a BOV recommended/required?
Old Mar 27, 2006 | 11:10 PM
evilundisguised's Avatar
Just as the title says... Is a blowoff valve needed for low boost levels (5-6 psi)? In higher boost applications, will the valve open at any boost > 0psi when you let off the throttle?
Old Mar 28, 2006 | 09:54 AM
OBE1 95Z28's Avatar
Re: At what boost level is a BOV recommended/required?
If you MAF is located just before the TB, you can run a BOV at any boost level. You didn't tell us what setup you're running; if it's a SC, most installations have the MAF before the blower and you cannot run a BOV as you'll be venting metered air and screw up your air/fuel ratio. Your bypass valve recirculates unused boost when you close the TB blades.
Old Mar 28, 2006 | 11:42 AM
I'm still NA at the moment, but thinking ahead... how about for an STS system? Obviously I would need the BOV to be placed before the MAF sensor, but is it really needed with only 5psi of boost?
Claimed "benefits" of a BOV: (please add if I'm missing something)
1- prevent damage to turbo by pressure backsurge
2- maintain turbo rpms between shifts w/ a manual trans
3- make sneezing noise when it blows off
does anyone have any firsthand experience as to whether or not any of these things are pertinent to a low-boost STS system?
Old Mar 28, 2006 | 11:44 AM
viper03af's Avatar
http://www.turbov6camaro.com/BOV.html << good read on how they work
my turbo surges at only 3 psi boost if i don't let off the gas all the way
Old Mar 28, 2006 | 06:01 PM
EVEN if, or ONLY if you don't let off the gas all the way? Is 3psi your max boost?
Old Mar 28, 2006 | 06:05 PM
viper03af's Avatar
only if, the BOV does not see vac and never opens..... point is its going to surge at any boost level....
my max boost is 17 psi
Old Mar 28, 2006 | 07:28 PM
Ah ok. So then the question still is whether or not there will be any benefit to having one with boost levels not exceeding 5 psi...? Will I be risking damage to anything (turbo parts, throttle plate...)?
Old Mar 28, 2006 | 08:19 PM
viper03af's Avatar
surge is hard on the turbine over time its wheres it out faster
Old Mar 29, 2006 | 03:14 PM
viper03af's Avatar
IMO any system should have a BOV, some people will say autos dont need them but i disagree.
i think any boost system should have a BOV.... even SC systems
Old Mar 29, 2006 | 07:17 PM
That's fine, and I respect your opinion... I just prefer to have as much information, quantitative or qualitative, as possible when learning about something. So keep it coming
Old Apr 1, 2006 | 07:21 PM
snorkelface's Avatar
I guess I still don't understand why you would need a BOV when utilizing a bypass valve.
Old Apr 1, 2006 | 07:23 PM
viper03af's Avatar
BOV vents into the air
bypass vent it back in front of the maf...... if you vent into the air after the maf the car goes rich and dies
Old Apr 20, 2006 | 04:12 PM
blown383's Avatar
Simply put... BPV for supercharger and BOV for turbo.
-B
Old Apr 20, 2006 | 04:56 PM
Roadie's Avatar
-B
except in the case of blow-through MAF... Then BOV before MAF.
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Louey
Pacific
Oct 1, 2015 12:37 AM
drt
Sep 27, 2015 04:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
