At what boost level is a BOV recommended/required?
Just as the title says... Is a blowoff valve needed for low boost levels (5-6 psi)? In higher boost applications, will the valve open at any boost > 0psi when you let off the throttle?
Re: At what boost level is a BOV recommended/required?
If you MAF is located just before the TB, you can run a BOV at any boost level. You didn't tell us what setup you're running; if it's a SC, most installations have the MAF before the blower and you cannot run a BOV as you'll be venting metered air and screw up your air/fuel ratio. Your bypass valve recirculates unused boost when you close the TB blades.
I'm still NA at the moment, but thinking ahead... how about for an STS system? Obviously I would need the BOV to be placed before the MAF sensor, but is it really needed with only 5psi of boost? Claimed "benefits" of a BOV: (please add if I'm missing something) 1- prevent damage to turbo by pressure backsurge 2- maintain turbo rpms between shifts w/ a manual trans 3- make sneezing noise when it blows off does anyone have any firsthand experience as to whether or not any of these things are pertinent to a low-boost STS system? |
http://www.turbov6camaro.com/BOV.html << good read on how they work
my turbo surges at only 3 psi boost if i don't let off the gas all the way |
my turbo surges at only 3 psi boost if i don't let off the gas all the way EVEN if, or ONLY if you don't let off the gas all the way? Is 3psi your max boost? |
my max boost is 17 psi :D :eek: |
only if, the BOV does not see vac and never opens..... point is its going to surge at any boost level....
Ah ok. So then the question still is whether or not there will be any benefit to having one with boost levels not exceeding 5 psi...? Will I be risking damage to anything (turbo parts, throttle plate...)?
IMO any system should have a BOV, some people will say autos dont need them but i disagree.
i think any boost system should have a BOV.... even SC systems |
I guess I still don't understand why you would need a BOV when utilizing a bypass valve.:confused:
bypass vent it back in front of the maf...... if you vent into the air after the maf the car goes rich and dies |
Simply put... BPV for supercharger and BOV for turbo.
-B |
-B |
