What boost
Re: What boost
The stock Vortech system (6" crank pulley, 3.33" blower pulley) for a stock LT1 makes 6# boost at around 6K rpm. I wouldn't run higher boost than that unless you run forged pistons and an intercooler or alky injection. If you do decide to pulley up, first add a 7" crank pulley to minimize belt slippage. The 7"/3.33" combo should get you 9# of boost.
Re: What boost
measure by the grooves...
Yeah mine hit almost 6psi on my 6" and 3.33", it was a little lower due to my cam and heads. Not to hijack this, but does anyone know what a 6" crank and a 3.0" blower pulley will do? 8ish psi maybe???
Re: What boost
i talked to vortech and they said to figure about 2#'s per pulley size. I have the same set up and mine makes 6-7 lbs and I bought the 2.95 pulley, 2 sizes smaller and they told me to expect 11-12 lbs.
Re: What boost
hey obe1, what size belt do you need when you go to the 7" CP? and does anyone make them besides vortech.
i dont need a new belt yet (im still running stock pulleys), but i know vortech wants way too much for theirs.
Re: What boost
I'll look up the size tonight when I get home from work; Vortech doesn't make the belt, you can get them from a local parts store. I'll let you know the brand; it was either a Gates or Goodyear belt.
Re: What boost
cool. i figured that a local autostore would carry the same belts. a replacement belt for the standard 6psi kit, vortech charges 42 bucks.
Re: What boost
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Aug 4, 2015 09:32 AM
