How much HP are you making with your supercharger?
So how much horsepower are you guys making with your supercharger set-ups?
Looking mostly for guys running stock motors [no boring/stroking, or major internal work]. How much hp at the flywheel and how much hp at the rear wheels?
Re: How much HP are you making with your supercharger?
I made 449 478 with 8 pounds of boost with an fmu and full stock timing
now i make what you see in the sig
The motor is now in a 69 camaro still running like like a champ
Originally Posted by JWS6
498/515 with the motor seeing 9lbs boost. Through exhaust manifolds!
i feel my numbers are weak, so ill include the details.....dyno test only went to 5k rpm, running butt rich at 10.2 AF ratio with 10* retard per pound of boost (way conservative). this was the dyno results i sent to the tuner to make the program.
380 rwhp, 392rwtq......so with less retard and a better AF ratio and 800 more RPM, im sure im putting out well over 400rwhp.
the reason im running so much retard is because of the horror stories of destroying pistons. the car is a blast to drive, so im runnin it till it blows, then ill rebuild it right.
jeremy
Originally Posted by ss#1230
...running butt rich at 10.2 AF ratio with 10* retard per pound of boost (way conservative). this was the dyno results i sent to the tuner to make the program....the reason im running so much retard is because of the horror stories of destroying pistons. the car is a blast to drive, so im runnin it till it blows, then ill rebuild it right. jeremy
im sorry. i had the dial on the crane ignition set @ 10*. which i think takes it up to 10deg. not per pound of boost. my bad.
im trying to find out exactly how it works (how much per pound it pulls) but i cant find the crane manual anywhere.
Damn, you guy's are making some good numbers with a P600B, relatively stock motors, and low boost. I have a 12lb P600B I've been trying to sell, but I may use it now that I've read this.
