water tank dimensions???
Old Jul 16, 2006 | 08:09 AM
bowtiepwr's Avatar
>so what size water tank are you using for your intercooler? and where did you install it? I want to use the Jegs 5 gallon tank
http://www.jegs.com/webapp/wcs/store...chItemId=72971
any suggestions?
Old Jul 17, 2006 | 07:52 PM
bowtiepwr's Avatar
Re: water tank dimensions???
any suggestions?
>so I ordered the 3 gallon instead... probably a mistake and will order the 5 gallon when the 3 gallon gets here
Old Jul 17, 2006 | 11:59 PM
JZ 97 SS 1500's Avatar
3 gallons is enough, and make sure to use a heat exchanger if you plan to daily drive it.
JZ
Old Jul 18, 2006 | 07:07 AM
bowtiepwr's Avatar
JZ
>I ordered B&M Hi-Tek Cooling System 130-70298 from Jegs...
http://www.jegs.com/webapp/wcs/store...chItemId=71671
Old Jul 18, 2006 | 09:37 AM
That will work perfect. Its the same unit I'm using.
pimpen1024
Aug 19, 2015 08:36 PM
350350
14
Aug 11, 2015 12:03 PM
MikeWhitener
Aug 2, 2015 06:17 PM
Noct
Jul 14, 2015 01:18 AM
Boss002
Jul 9, 2015 03:33 PM
