water tank dimensions???
>so what size water tank are you using for your intercooler? and where did you install it? I want to use the Jegs 5 gallon tank
http://www.jegs.com/webapp/wcs/store...chItemId=72971
any suggestions?
any suggestions?
Re: water tank dimensions???
any suggestions?
any suggestions?
Originally Posted by JZ 97 SS 1500
3 gallons is enough, and make sure to use a heat exchanger if you plan to daily drive it.
JZ
JZ
http://www.jegs.com/webapp/wcs/store...chItemId=71671
14
Aug 11, 2015 12:03 PM
Noct
Jul 14, 2015 01:18 AM
