Water/Methanol quick question...
Old Dec 10, 2006 | 06:12 PM
roguedriver's Avatar
On a water/meth mix, if it sits for a period of time, will one or the other evaporate to a point where your mixture will change? Say like a 50/50 mix. Will your water or methanol evaporate off leaving more of one or the other? Just curious. Thanks.
Ken R.
Old Dec 11, 2006 | 10:09 PM
Kevin Blown 95 TA's Avatar
Mine doesn't seem to evaporate, I've marked the washer tank with tape to track usage and it only has a pin sized hole for a vent for the stuff to evaporate from.
But, I was wondering if it goes stale in some other kind of way?
Old Dec 12, 2006 | 11:09 AM
byrons1502's Avatar
does your washer solvent get lower without use? i don't think it changes much at all
Old Dec 12, 2006 | 03:09 PM
InsuranceGuy's Avatar
I can't tell you the mix ratio but the stuff definately evaporates.
My car has sat up for 13 months and my two quart resorvoir
has evaporated down from almost full to almost empty.
As cheap as methanol and distilled water is I would dump the
stuff if it sat over a couple of months.
Emil
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
