water meth question
Old Aug 30, 2008 | 04:31 PM
does it end ?'s Avatar
water meth question
I'm about to install my water injection kit and I wonder how well it's going to distribute to all 8 cylinders? I plan on tapping into the elbow But is there a better way. To insure that all 8 cyl. get quenched?
Old Sep 1, 2008 | 12:54 PM
CALL911's Avatar
To my knowledge, theres no kit available that does what a direct port nitrous system does in the intake, although it would probably be more efficient in getting the same amount of water/meth injection to all 8 cylinders as you are talking about.
FWIW, I have mine tapped into my elbow, and it has worked flawlessly for years, and really is great at keeping my IAT's nice and cool and keeping me safely away from detonation without having to spend the crazy money on race gas.
Old Sep 2, 2008 | 10:08 AM
boosted-lt1's Avatar
All the kits out there spray before the throttle body. If this was a real problem I'm sure the TurboBuick guys would have worked around it. Check with the Buick message board (they have an alky inj. section) and/or ask Julio.
-Scott.
Old Sep 4, 2008 | 03:42 PM
Kevin Blown 95 TA's Avatar
Make sure your kit is fairly high pressure and it has nozzles that aren't too big so that you atomize the water/meth as well as possible - that might help distribution by keeping the droplets as fine as possible. two small nozzles are usually better than one large one.
Old Sep 4, 2008 | 11:02 PM
FL-LT1's Avatar
yeah julio or RAZR up on the buick board is a manufacturer of alky kits at alkycontrol.com he can help you with just about any question you have pertaining to meth water injection kits.
Old Sep 14, 2008 | 01:03 PM
thanks, guys. I'm going to roll with it and hope for the best..
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
