water injection or intercooler?
I have a 69 camaro with 93 LT1 with a procharger p1sc.I am running 9 lbs of boost with 9.2 to 1 compression.I am currently running a low cost water injection kit.The car runs 11.60s now .My question is will i benefit from a inter cooler enough to make it worth while.Thanks for any input.
Re: water injection or intercooler?
Do you have a data logging program? Check you IATs and search to see what others have. I have seen about 120* on the dyno when it was 70* outside. You would most likely see gains but you have to weigh that against the cost involved if you care about spending money.
ever thought of one of the $300 intercoolers on ebay? I've also heard of people using power stroke intercoolers on 90's turbo stangs. They run in the $300-400 range from the right sources.
Formula Steve
Sep 19, 2023 08:31 AM
RUENUF
Mar 13, 2016 03:37 PM
tdigger9899
Sep 7, 2015 10:56 AM
