Wastegate and BOV Size
Old Dec 7, 2007 | 12:33 PM
c0rey's Avatar
Im looking for some wastegate and bov help. Im looking at a xo2 racing 44mm wastegate because Im going to be running low boost 6-7lbs with a MP t70 so it should spool pretty fast. I just want to make sure that the wastegate will be sufficent because all the bigger ones start with 9lb springs.
And for a bov reccomendations as well. Turbo newb sorry.
Old Dec 7, 2007 | 01:27 PM
RealQuick's Avatar
So I have been back and forth with one of the XO2 reps and even the 44mm comes with a minimum spring of 9psi, but some people have used Tial 44mm springs and been fine (they have 5psi springs).
Aside from the spring issue, a 44mm gate will be fine. Justin had no problem running low boost with his 44mm gate.
Supposedly Jose at forcedinductions used a turbosmart 38mm on his 383 setup.
For a BOV... anything really. You could get the 50mm Tial, the 50mm XO2 BOV, the JGS BOV. You could also look into the Raptor BOV and some of the other Non Tial style BOV's
Old Dec 7, 2007 | 01:41 PM
jsetzer's Avatar
I used two ebay 25mm BOVs for dirt cheap and so far they work. Sound kind of neat too.
I am running a turbonetics 42mm racegate - Haven't really tested it much yet.
Old Dec 7, 2007 | 02:06 PM
c0rey's Avatar
Any pics of this? Are you guys venting to atmosphere are connecting in with the dp. What brand on ebay.
Old Dec 7, 2007 | 02:35 PM
jsetzer's Avatar
Mine have round heads not hex, but the same design. Downside is they do not bolt or clamp on, but with just hoses and good clamps they have stood up to 10psi a few times so far.
http://cgi.ebay.com/ebaymotors/BLOW-...em230200651045
So far my 70 has made boost incredibly fast. I fear it is a bit small for a heads/cam small block. But we will see where it goes.
Old Dec 7, 2007 | 02:38 PM
jsetzer's Avatar
No good shots of the bovs but you can see them hanging in front of the filter here...
Old Dec 7, 2007 | 02:46 PM
RealQuick's Avatar
Thats a good gate... but pricey.
Old Dec 7, 2007 | 02:48 PM
jsetzer's Avatar
I stole it.
When I have to give it back I will probably get an ebay one.
Old Dec 7, 2007 | 03:07 PM
RealQuick's Avatar
I stole it.
Old Dec 7, 2007 | 04:08 PM
c0rey's Avatar
Well realquik did you ever resolve the problem with them about the 9 pound spring? Do they(xo2) have other springs or just that one?
Old Dec 7, 2007 | 06:09 PM
RealQuick's Avatar
Their wastegates (particularly) the 60mm is based of the HKS design and uses the HKS springs (which 9psi is the smallest). Sounds like you can use a Tial spring on the 44mm though.
Old Dec 8, 2007 | 08:00 AM
c0rey's Avatar
I am about to order the 44mm and a set of tial springs and hope they will work.
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
surreybrad
Sep 29, 2015 09:00 PM
autoxr166
Sep 25, 2015 04:21 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
