Vortech install question - oil pressure unit
Old Aug 20, 2005 | 07:27 PM
DarkHorse's Avatar
Ok - on 93 and early 94's it seems the oil pressure sending unit is installed near the oil filter. My question is - I have a 94 and if it is NOT located near the filter is there at least a plug there that I can use for the Vortech fittings?
As it stands Vortech says to remove the sending unit and place it on their "T" fitting then screw the T fitting into where the sender was. I'm pretty sure that my sending unit is mounted on the back of my intake. Is there a plug that I can remove and still install the T near the oil filter? Or do I have to run Vortech's T fitting to the rear of my intake?
Old Aug 20, 2005 | 10:55 PM
Z8'S's Avatar
Re: Vortech install question - oil pressure unit
There is a 1/4 npt tapped plug above the oil filter .Connect there.
Old Aug 20, 2005 | 11:23 PM
DarkHorse's Avatar
Got it - thanks.
That means I don't need a tee.
Old Aug 21, 2005 | 02:22 AM
97WS6SCharged's Avatar
Nope, no T fitting. Just a 3" EZ fitting, 1/4npt to 1/4npt.
HectorM52
Jul 30, 2017 11:46 AM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Jul 4, 2005 05:00 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
