Vortech Crank Pulley???
Old Mar 13, 2006 | 11:58 PM
esb311's Avatar
I have been searching forever, is there anyone that makes the 7 inch vortech crank pulley??? If so a website would be awesome, thanks a lot
Old Mar 14, 2006 | 06:35 AM
[JFS]'s Avatar
Re: Vortech Crank Pulley???
sent pm
Old Mar 14, 2006 | 07:18 AM
roguedriver's Avatar
ASP pulleys makes them. I'm having them custom make me a 7" for my Vortech with my ATI damper cause the original pulley is now offset. But they should make the standard 7" for the vortech also. Don't know the site but do a google search for ASP pulleys.
Ken R.
Old Mar 14, 2006 | 09:31 AM
Flip94ta's Avatar
I also have the ATI/ASP combo, works well.
Did your factory dampner fly off as well?
Old Mar 14, 2006 | 02:57 PM
No, didn't fly off. Just dropped a 383 in and went with the dual keyed hub ATI but didn't even think about it being offset slightly. Don't like having the tensioner and charger pulley shimmed out either. Found out that ASP custom makes them when i called so went with them. Glad your happy with your pulley. Makes me feel better. Was it a bolt up pulley? All holes lined up fine and also lined up with your tensioner and charger pulley with no shimming needed?
Ken R.
Old Mar 15, 2006 | 07:36 AM
Flip94ta's Avatar
Its a good pulley, and it looks great. It fits tightly inside the ATI and you may need a rubber mallet to get it in there, it wasn't too bad. I think I am using a 42.5 inch belt with a 2.85 upper pulley.
Old Mar 15, 2006 | 09:49 AM
Thanks Flip. Thats the pulley combo i'll be using. Do you happen to have a number off your belt in case i need to cross reference it when I go get one? How much boost are you pushing through your 355 with that combo by the way? Thanks.
Ken R.
jbert55
Oct 31, 2015 03:52 PM
4586
Aug 18, 2015 07:08 AM
Slayer
Aug 17, 2015 03:55 PM
Catmaigne
Jul 14, 2015 05:17 PM
