Video of my procharged 69Z28
Old Aug 8, 2003 | 03:22 PM
  #16
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Just incase you didn't know, to run without a thermostat with an LT1 car, you must plug the bypass hole beneath it.
MSM69Z28- Nice ride
Old Aug 8, 2003 | 03:50 PM
  #17
MEAN LT1's Avatar
Originally posted by iwon
the thermastat is there for a reason, it holds hot water in the radiator to be cooled then sent to the engine where the water from the engine is then cooled then cycled again, by having hot water contiully going around the engine it will only get hotter or have bad cooling effect.
i suggest you put a 160* stat in there and get you fans programed or timed to come on early, just my $.02
Hehe...I did have a 160* thermo in my car and my fans have been programmed already. Im fine running the car with no thermo, its not hurting anything and it surely isnt helping me at this point either. Thanks anyway though
Old Aug 27, 2003 | 10:07 PM
  #18
ltlhomer's Avatar
One of the sweetest rides I've seen in a long time. That is the perfect idle! Blower belt whining w/ nice cam lope.
AWESOME car man! Keep the videos comin' .
Old Aug 27, 2003 | 10:12 PM
  #19
Jcb890's Avatar
It didnt work 4 me
Jake
Old Aug 28, 2003 | 11:01 AM
  #20
MSM69Z28's Avatar
i have to get it loaded on another site. bandwidth sucked up. 7500 downloads and 40GB later...
lol
Old Aug 28, 2003 | 09:49 PM
  #21
nxfirebird's Avatar
question for you, i see you used a Vortech carb box instead of the ATI carb bonnet. what are the pros and cons of the "bonnet" VS the "box"
Old Sep 1, 2003 | 09:03 AM
  #22
MSM69Z28's Avatar
actually, this has been talked about quite a bit on another forum.
http://www.boards2go.com/boards/boar...ser=huntracers
either one has been proven to work very well. i liked the box for its looks more so than performance, but i can't complain so far.. the box has worked out very well. honestly, the nicer bonnet hats might make more power due to the direct flow (hasn't been proven though.., just my opinion), but the box probably makes for easier tuning and driveability. this is debatable. the box does make it more difficult to do the little changes to the carb, but pressurizing the whole carb makes for no mods to the carb to take boost (aside from solid floats).
hope that helps. do a search, this has been discussed in more detail.
mike
Old Sep 1, 2003 | 10:35 AM
  #23
nxfirebird's Avatar
thanks!!!
CARiD
Sep 30, 2015 05:44 AM
HAWG
Sep 25, 2015 11:41 AM
95blkss
Sep 22, 2015 03:18 PM
mark0006
Sep 14, 2015 12:35 PM
