UPDATE Pic's
Old May 5, 2005 | 11:33 PM
Schurters LT1's Avatar
UPDATE Pic's
ok got some more pic's and set this up a little better...frist time with the doing all this..
-Jeremy
http://client.webshots.com/user/jschurter
Old May 6, 2005 | 01:52 AM
n2oblkz
Guest
Posts: n/a
Re: UPDATE Pic's
I'm planning on using the Versafueler also. Is it a plug-n-play setup or is it a cut and splice? I saw the connectors and got a little confused.
Old May 6, 2005 | 02:43 AM
Alex94TAGT's Avatar
Re: UPDATE Pic's
Schurter -- Thanks for sharing photos. How 'old' would you say that Versafueler is? I just got mine last week, and it actually looks nothing like that. I guess they must have redesigned it at some point. I'll snap some photos...
Also, I was going to ask where you mounted (or are going to mount) your MSD booster. Racetronix said to mount it as close to the fuel pump as possible. They know far more about it than I do, but I'm not certain if it would make a HUGE difference either way. I'm not sure what fuel pump you're running, but I don't believe we are to exceed 16v with the Walbro 255...
N2Oblkz -- You have to splice into the factory wiring -- between the fuel injectors and the computer. All 8 injectors share the same power source, but the computer is fed all 8 separate injector ground wires -- & decides when to ground out each injector, as I understand it. The VersaFueler intercepts the 'control wire' to the computer, but also has its own separate power/ground wires. So, there's some wiring involved. You've got 16 splices to make, and then your power/ground.
Old May 6, 2005 | 05:30 AM
n2oblkz
Guest
Posts: n/a
Re: UPDATE Pic's
Posted by: Alex94TAGT
Cool, thanks for the info.
Old May 6, 2005 | 08:06 AM
Re: UPDATE Pic's
I bought it off a board member back in Jan, it is new everything was still in the bag
The BAP i am going to look into the rear seat? I am running everything that racetronix sells...and i read a post where they talked about putting it under there D/S rear seat put the BAP at full and with the heavy wire the Voltage should fall down to 16.5V and that is what you want....
[QUOTE=Alex94TAGTN2Oblkz -- You have to splice into the factory wiring -- between the fuel injectors and the computer. All 8 injectors share the same power source, but the computer is fed all 8 separate injector ground wires -- & decides when to ground out each injector, as I understand it. The VersaFueler intercepts the 'control wire' to the computer, but also has its own separate power/ground wires. So, there's some wiring involved. You've got 16 splices to make, and then your power/ground.[/QUOTE]
Yes you have to cut into the factory wiring not a big deal i hard wired mine in just to be safe and used heat shrink....
http://www.acceleronics.com/
there is info here....
this will help as well
http://shbox.com/1/schematics_wiring.html
Old May 8, 2005 | 05:22 PM
Re: UPDATE Pic's
a few more update pics of alky install
Old May 15, 2005 | 02:57 PM
Re: UPDATE Pic's
More Update pic's...........
WHere is good place to put the controler in the car???? any ideas
Old May 15, 2005 | 05:00 PM
Live for TAs's Avatar
Re: UPDATE Pic's
I put my MSD BAP under the driver side rear trim panel by making an aluminum bracket for it to sit on, and then ran the pressure line & wiring under the trim panel then under the rear driver side seat out the plug at the bottom (ran the pressure hose inside of 3/8 aluminum fuel line for protection) and made connections to the Racetronix harness OK.
YMMV on the pressure line routing since my turbo is at the "wrong" end of the car .
Here are 2 pics of the BAP install:
http://memimage.cardomain.net/member...7_176_full.jpg
http://memimage.cardomain.net/member...7_171_full.jpg
Old May 15, 2005 | 05:16 PM
Re: UPDATE Pic's
cool thx for the idea....on the BAP
I am looking for ideas on where to mount the alkycontroler ????
thx
Fastbird93
Apr 9, 2016 07:01 PM
warmeck
Mar 22, 2015 06:43 PM
cmsmith
Mar 16, 2015 02:34 PM
Z28SORR
Mar 6, 2015 11:17 PM
