turbo and tuning...
Old Jan 29, 2006 | 07:32 AM
  #16
engineermike's Avatar
Re: turbo and tuning...
363 LT1
PT-76GTS at 13 - 20 psi
Stock ECM, 84 lb/hr injectors/Impedence converter, Crane HI-6TR
I tuned mine for cold weather at about 11.8/1 Air Fuel ratio. In the summer, that will drop to about 10.8/1. The difference isn't as much as most people think. Sure 10.8 isn't the greatest for power, but keep in mind that a stock Ford Lightning runs about 10.5/1.
Pro's of the stock ECM:
- Gauges and VATS key system work fine without having to piggyback computers.
- Cost. Impedence converter and TunerCAT total about $500 versus $2500 for many of the aftermarket ECM's and piggyback harness.
- Factory tune is pretty dang good in most cases, so you're already in the ballpark.
Con's of the stock ECM:
- Doesn't compensate for temperature when MAF is max'd out.
- Reportedly not as responsive as aftermarket (on throttle tip-in).
Old Jan 31, 2006 | 05:28 AM
  #17
JWBerk94Z's Avatar
What is a BS3? Two posts here mentioned it, but I am not sure what that stands for or who makes it.
Old Jan 31, 2006 | 05:49 AM
  #18
RealQuick's Avatar
Big Stuff 3.....
If you google it, you should find something.
Old Jan 31, 2006 | 06:17 AM
  #19
JWBerk94Z's Avatar
Ah, thanks. I have heard of it before, it just didn't click.
95blkss
Sep 22, 2015 03:18 PM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
