Turbo LT1 - Check it out
Re: Turbo LT1 - Check it out
Originally Posted by Flip94ta
That black TA makes the this thread a whole lot better, what hood is that and how is the fitment?
definately. that black t/a is real nice lookin. only thing better than a turbo is bein able to see it (w/o stickin out of the dumbass hood).
nice setup, props on the design.
Sorry....I puked in my mouth a little.
I don't care for the turbo placement or the car as a whole. But as long as you're happy with it, that's all that matters.
I am going to make more this fall.
Sparkplugs from underneath car.
SunCoast hood.
On factory installs some other mods must be made in the area of ABS and Pass side cross over. I am working with a stainless duel under hood kit right now, but looks like it will require a bubble or cowl on factory hoods except ram air - also depend on power level.
Thanks Guys...
Wingnut
SunCoast hood.
Thanks Guys...
Wingnut
is the black car the one in your sig? how much boost?
the kit on the black car looks interesting except the first two primaries on the driver side just kinda right-angle into the collector, that cant be good for flow.
and is it just me or does the whole passenger bank empty into just half of the collector before the turbo?
Yes it is the car in the sig, #'s at 15psi. New system has close to = length runners. The "stove pipe" is open on inside with a couple of airfoils to direct flow and reduce hot spots and high-pressure areas. Efficiency drops off after 18PSI. Car made 520 RWP @ only 8PSI and <5 PSI exhaust pressure. At 16PSI boost and exhaust pressure cross and rises almost y=x^2. This fall will see a new system again.
Guys this is not the best system, however, it does use fewer bends and breaks then some of the systems on the market. One should test some of the other systems for exhaust pressure vs intake pressure. One may be surprised... This system is but a proof of concept testing theories of thermal dynamics regarding efficiency gained through the natural tendencies of hot pockets of air.
Wingnut
what kind of turbo lag do you experience with the T-88? just curious because I went with a T-76GTS because my friend had a T-88 an it lagged a little, an when he went to the T-76GTS it was like a while new animal, but i imagine the top end power is still unbelievable once it spools
wingnut
The turbo setup is wierd, why the hell is it out of the hood.
We should have our twinturbo lt1 setup done in the next few weeks. I have already made one header and will hopefully start on the other one this week. Will keep you posted...will have pics hopefully soon.
Wingnut
Swallow...and tell us which one??
Didn't care for the red car at all. The only picture I saw of the black TA is the side by side. Any more pics or am I just blind?
-Small Block LT-1, 5.7 litters
-Turbonetics T-Series (T70) Turbo
-Turbonetics Racegate Wastegate
-Turbo XS Type H-RFL (Really F*king Loud)
-100shot Wet NX kit
-Custom Stainless Steel Turbo Manifold
-Custom 2.5 Cross Over Pipe
-Custom FMIC
-Vortec FMU
-Injectors (Secret) __ __cc.
-2-Walbro 255LPH (In Tank) Fuel Pumps
i didnt know they made injectors for a camaro with cc's
-100shot Wet NX kit
-Custom FMIC
-Vortec FMU
There should have been several on the page, even a couple of the engine on the stand...
wingnut
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
