new times, hot cam procharged
Just wanted to update you guys on my most recent track times. I ran an 11.20@124. That was with a 1.61 60ft. I still babied it off the line because I'm still running the factory rear. This run was with factory heads, crank, rods, intake, and rear! My mods are in my sig. I'm going to do a rear with a trans break here soon because I know I'm on borrowed time with the factory rear. This run was also with a mail order tune from fast chip.
Re: new times, hot cam procharged
Great times, I'm glad to see that cause thats pretty close to whats going into mine right now (parts in sig). I can't wait to finally get it running. Probably about a month away still.
Thanks for the reply! I'm pretty happy with the times. I want to hit 10's with this combo. Pretty sure I'll do it with a rear and a trans brake. Also the elevation on that run was at 1300 ft. I absolutely love the qa1's by the way!
Very nice times. When I had LT4 conversion on stock bottom end and 10psi I wasn't anwhere close. Of course I was pulling 2.2 60's. Looks like you got it figured out pretty good.
Originally Posted by CJ
Be carefull you might get called out by some of the STS guys...
They can threaten to run him from a 100 roll
teedoff59
Aug 8, 2002 01:36 AM
