Turbo Experts in here please
Old 06-20-2006, 07:47 PM
ChrisUlrich's Avatar
Moving 72lbs per minute... that should support 700whp right?
49lbs per minute supports 460whp.
What is the exact formula for that? How does this work? Can anyone help me out here?
The benchmarks are used on SRT4 motors just incase that's a question.
ChrisUlrich is offline
Old 06-20-2006, 08:19 PM
Kevin Blown 95 TA's Avatar
Re: Turbo Experts in here please
You know of a 700 whp SRT4?
Kevin Blown 95 TA is offline
Old 06-20-2006, 08:44 PM
mn_vette's Avatar
The rough equation is 100 hp for every 10 lb/min of air moved. The exact numbers are widely dependent on humidity and temperature.
mn_vette is offline
Old 06-20-2006, 09:04 PM
There's a couple... yea
Old 06-20-2006, 10:10 PM
That's a wild amount of power for a little car like that.
Old 06-21-2006, 03:21 PM
97WS6SCharged's Avatar
You've never seen some of the ecotech drag cars making 1000+ hp?
http://www.thecarconnection.com/Enth...247.A5482.html
97WS6SCharged is offline
Old 06-21-2006, 06:40 PM
Maybe I'll build a sunfire convertible with a 1000 hp ecotech engine...
Old 06-21-2006, 07:23 PM
Only if you post a vid of the boost gauge passing 40 psi.
Old 06-23-2006, 09:20 AM
blackztpi's Avatar
720 hp has to suck on FWD. get those babies spinning and there goes your steering...not to mention torque steer. hot damn
blackztpi is offline
Old 06-23-2006, 11:25 AM
Zigroid's Avatar
it depends on engine variables. check here:
http://www.turbobygarrett.com/turbob...o_tech103.html
scroll down to where you see:
theres a good equation to figure it out.
Wa = Airflow in lb/min
HP = horsepower
A/F = air/fuel ratio
BSFC/60 = brake specific fuel consumption ÷ 60 (to convert from hours to minutes)
for a 720 horsepower engine:
Wa = 720(horsepower) * 12(air/fuel ratio) * .55/60 (BSFC/60)
that comes out to 79.2 lbs/hour.
Zigroid is offline
95blkss
09-22-2015 03:18 PM
cmsmith
09-14-2015 09:09 PM
NewsBot
09-14-2015 02:02 AM
sleeperZ96BT
09-10-2015 08:01 AM
LeftoverChinese
07-23-2015 03:57 PM
Quick Reply: Turbo Experts in here please
