Turbo exhaust
Old Jul 31, 2004 | 06:38 AM
  #31
SMOKNZ's Avatar
Re: Turbo exhaust
Originally Posted by Geoff Chadwick
12psi was not stock. 12psi was on forged pistons, ls1 rods at the very least, and I've heard mixed wording that it was also a 383 engine.
If you try to tell me a hypo piston and the factory pins can take those forces and I will never believe you. Nitrous on an lt1 I can see, but the heat you're talking about here will crack the pistons, blow ringlands, or heaven forbid destroy the pins. The stock pistons have the ringlands too high for a good boost setup.
Heat will not crack the stock Hyper pistons... Detonation does. Grab a set of 78cc combustion chamber AFR heads, slap them on the stock shortblock and I bet the pistons will live a long happy life. The lower compression due to these heads will give a safety cushion in the tune. FWIW many stock turbo cars run hyper pistons. 10.5:1 is just to high for forced induction, detonation does usually happen to all but those with the best of tunes, thats why all those 8 psi blower cars are, well.... Blowing
It isn't the Hyper's fault... It's the car owners (and I'm one of them)
Bill
Old Jul 31, 2004 | 08:04 AM
  #32
Josh-'04 GTO's Avatar
Re: Turbo exhaust
Originally Posted by trtturbo
IAT @ 5psi w/o meth is 115 degrees.
What was ambient temp at the time of that run?
Old Jul 31, 2004 | 09:55 AM
  #33
trtturbo's Avatar
Re: Turbo exhaust
I dont know the ambient temp, but if it helps, the turbo outlet temp was 175 and the intake temp was 115. At 8psi the turbo outlet temp was 225 and with the meth, intake temp was 70 degrees.
Old Jul 31, 2004 | 12:49 PM
  #34
5.0THIS's Avatar
Re: Turbo exhaust
I meant what were the IATs at high boost levels without methanol, or has anyone had the ***** to try it. I dont want to have to run methanol just to be able to run boost levels that any other kit doesnt require methanol to run.
Old Jul 31, 2004 | 02:13 PM
  #35
trtturbo's Avatar
Re: Turbo exhaust
keep in mind, we dont run an intercooler. To run higher boost, you need to do something to cool the charge temps. I had the 8psi with meth on my LS1, but changed my mind with stock fuel system and pistons. I would not run the 8psi w/o meth. The thinking behind these systems is outside of the box, but I personally am very satisfied. Check out the FAQ's on www.ststurbo.com
Old Jul 31, 2004 | 04:57 PM
  #36
97z28/m6's Avatar
Re: Turbo exhaust
could you use an intercooler insted of meth?
Old Jul 31, 2004 | 05:04 PM
  #37
trtturbo's Avatar
Re: Turbo exhaust
Yes, you could use and intercooler. I just sold an kit to someone with an Augostino turbo motor. He is using a t-70. Should make great power.
It would just be a matter of fabbing up a pipe to go to the intercooler, then from the intercooler to t.b.
Old Jul 31, 2004 | 06:45 PM
  #38
1stls1's Avatar
Re: Turbo exhaust
So no times on these w/out any other mods?
Old Jul 31, 2004 | 08:32 PM
  #39
trtturbo's Avatar
Re: Turbo exhaust
some are running low and mid 12's, but with great mph- 117 to 120 with street tires and high 60ft times.
Old Jul 31, 2004 | 08:44 PM
  #40
Re: Turbo exhaust
Has anyone measured the lag time on the STS kit vs. a standard turbo setup? Seems like a real long trip for the boosted air to travel. What about pressure drop measurements from turbo outlet to intake manifold?
Old Jul 31, 2004 | 09:18 PM
  #41
trtturbo's Avatar
Re: Turbo exhaust
All of this info can be seen on www.ststurbo.com
Old Jul 31, 2004 | 09:41 PM
  #42
SMOKNZ's Avatar
Re: Turbo exhaust
I thought alot of the STS guys were seeing full boost by 3500 rpm. It has the same characteristice of my kit, but I'm turning 2 turbo's. When the boost finally does hit... hold on
Old Jul 31, 2004 | 11:14 PM
  #43
trtturbo's Avatar
Re: Turbo exhaust
My car hits full boost at 3000. In first, its almost useless; just spins when it hits boost. I usually short shift 1st a little. In second, on all but good pavement, it spins more; just back pedal a little and go.
Old Aug 1, 2004 | 04:52 PM
  #44
1stls1's Avatar
Re: Turbo exhaust
Would this be useless w/ a auto?
Old Aug 1, 2004 | 08:22 PM
  #45
95mysticteal's Avatar
Re: Turbo exhaust
I rode in an auto & a six speed before deciding to make my purchase. 6 speed is a LOT of fun, but that auto will probably always beat it at the track because it's easier to get a great launch and you don't lose boost during shifts. If they had a kit for my auto vette, I'd be signing up for it. I keep telling Rick to find some time to get a vette kit together.
