turbo cfm formula
Old Aug 30, 2003 | 06:57 PM
newkoba's Avatar
turbo cfm formula
just curious is anyone here has the formula to figure out the cfm output of various turbos.
thanks
Old Aug 31, 2003 | 01:53 AM
Secret Formula's Avatar
If the turbo compressor maps show "lbs/min" you can divide that number by 0.069 to get CFM. For example:
50 lbs/min = 724.6 CFM
Old Sep 1, 2003 | 08:28 AM
arnie's Avatar
Without trying to get to complicated, it should be noted, that temperature is a variable that affects the weight of air. Using the .069 figure, will be accurate in determining cfm @115* F. This figure is not a constant, it will increase as air temp goes down, and visa versa. For instance, @80* F, the figure would be .0735. The weight of air is also affected by moisture content, but that is a separate issue.
Formula Steve
Sep 19, 2023 08:31 AM
PopoFormula
Oct 12, 2015 04:19 PM
Kawi
Sep 28, 2015 09:01 AM
cmsmith
Sep 14, 2015 09:09 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
