Turbo ????
Turbo ????
I have a couple of turbo questions.
I watch turbo cars at the track spool up at the starting line then when the launch it seems like the the engine shuts down, why is that?
Can you use a 88mm exducer compressor inside a frame design for 106mm?
What's the difference in sound from a small turbo to a large turbo?
It is likely what is known as a two-step revlimiter. By limiting the RPM at launch, one can't just blow the tires loose like an idiot. But, it also cuts the ignition which will send unburned air-fuel charges into the header; ultimately, this adds heat to the turbine and, effectively, spools it. This is the reason why you can mash the pedal on a turbo car — and keep it in a high gear — and have it spool up while the RPM changes very little (load responsive would be the effectual term).
No, you cannot put an 88mm compressor wheel in a cover designed for a 106mm wheel.
I think a big turbo making big boost sounds more menacing then a smaller turbo making big boost, but you should reserve judgment.
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 02:02 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
