Tuning for boost with stock pcm?
Old Apr 27, 2006 | 06:48 PM
  #16
will62085's Avatar
Re: Tuning for boost with stock pcm?
Originally Posted by CALL911
So let me get this straight, with the stock PCM, tuning on your own past 550 or so RWHP, is pretty difficult, if not nearly impossible. However, am I understanding things correctly, that it can be tuned properly by a dyno tuner when the power could be over 600-650 RWHP?
its not difficult, its just like carb tuning...if you have access to a wideband and a dyno, then you just look at AFR and tune your ve tables according to that.
Old Apr 28, 2006 | 09:09 AM
  #17
AlexA's Avatar
Originally Posted by will62085
while the MAF will be pegged out around ~550ish RWHP, you can instead tune with only speed density, no MAF. This requires runnign a 2 or 3 bar MAP sensor and rescaling all your MAP tables (your fuel enrichment table, MAP vs. RPM is the big one here) so that the computer still thinks its a 1 BAR sensor when in fact it is not. The computer output in a scan program will only read up to 1 Bar, so you have to know your re-scaling factor to know exactly where it is by the scan program... of course you should have a boost guage anyway to tell you this.
bottom line, it IS possible to tune for BIG HP with stock lt1 pcm...just kinda a PITA to make it work.
I was thinking this was the solution, but I didn't know you had to rescale the MAP table. I suppose the 2 bar MAPs are still 1-5V? So all you have to do is scale down the MAP fueling table by 2? For example, where it shows 25KPA is where it really should be 50KPA fueling? My car is currently tuned with the MAP table (naturally aspirated) - if I put a 2 bar MAP in and re-mapped the table, it would run exactly as it would before? Makes plenty of sense. Or maybe it wouldn't be perfect as I think the VE table would come into play...
-Alex
Old Apr 28, 2006 | 09:38 AM
  #18
OBE1 95Z28's Avatar
sorry for hi-jacking this...haha i just read your sig, ive seen your can in that mag., i was laid up in a hospital bed in may of 05 and my parents brought me that mag. for reading material...you dont know how many times i read that article...lol
and tuning like you are can be done, obviously, but unless the tuning is done on a dyno with a wideband, its kind of like shooting in the dark, the computer is in open loop, with no self correction of any kind based on MAP, or MAF readings because they will both be maxed out. It can be done though, after all, guys who run carbs and tune by seat of pants driving and checking sparkplugs are more in the dark than we are in this case... just food for thought
Jeff Creech flew out to CA and dyno tuned my car on a wideband O2 setup
Old Apr 28, 2006 | 10:37 AM
  #19
will62085's Avatar
Originally Posted by AlexA
I was thinking this was the solution, but I didn't know you had to rescale the MAP table. I suppose the 2 bar MAPs are still 1-5V? So all you have to do is scale down the MAP fueling table by 2? For example, where it shows 50KPA is where it really should be 25KPA fueling? My car is currently tuned with the MAP table (naturally aspirated) - if I put a 2 bar MAP in and re-mapped the table, it would run exactly as it would before? Makes plenty of sense. Or maybe it wouldn't be perfect as I think the VE table would come into play...
-Alex
you got it...the only problem with this is you loose some resolution on that table...but i honestly dont know how big a deal that is
Old Apr 28, 2006 | 02:56 PM
  #20
LT1-TA's Avatar
sure thing, the megasquirt II pcm has an on board ingition driver circuit that can be installed during the assembly. i am just using an old school cylinder 12 volt coil driven off the MSII. Im using an obdII crank sensor (for misfires on an OBDII car), which is a 4x even pulse crank sensor. this is used for rpm input on my MSII in the hall sensor setting. because of the uneven slots in the opti wheel, the opti cannot be used as a trigger input with the MSII, so i retrofitted this crank sensor.
the MS can preform just as well as the stock pcm, so as long as your emissions guy doesnt know its there, it can and will pass emmissions with the proper tune... lucky for me, no emissions where i am.
im goin to make a write up soon on my car domain page on how to install a MS on an LT1 since nobody else has been able to figure it out.
BTW, mine is piggy backed on my stock pcm, the stocker is just running guages and reverse lockout...
well i would use the the MS as a piggyback also... and i think i would do like Perish did on his turbo ls1 truck. Im going to let the pcm control the spark and gauges and whatnot, and have megasquirt control injectors. You foresee any problems doing this?
Old Apr 28, 2006 | 04:32 PM
  #21
95 Z/28 LT1's Avatar
Super Moderator
I was planning on going with the factory PCM with my '95, but I feel that there is too much extra stuff by the time I run a LTCC, MAF Eliminator, Versafueler, etc. like was mentioned earlier. For those reasons I'm just getting a BS3 and getting it over with.
I'm hoping it will save lots of hassles with reliability.
Old Apr 28, 2006 | 04:42 PM
  #22
will62085's Avatar
no, i just chose to have the ms control everything cause it is boost sensative, and didnt have to mess with tuning two computers
Old Apr 28, 2006 | 04:44 PM
  #23
will62085's Avatar
im sure it will save lots of hassles...but building your own pcm is just cool imo, i enjoyed doing it, and seeing something you built operate a 1000+ HP motor is just plain sick
Old Apr 28, 2006 | 05:22 PM
  #24
LT1-TA's Avatar
well how hard would you say that was to get MSII to control everything??? With all the stuff you rigged up? on a scale of 1-10.. lol...
and how much was the total cost of going from the LT1 PCM to megasquirt run.
sorry for all the questions, but im really stocked about trying megasquirt on something finally.
Old Apr 28, 2006 | 06:33 PM
  #25
will62085's Avatar
the cost for the MSII, test board (called the stimulator board), and the harness (universal with no pig tails) was about $400. took about 10 hours of soldering to assembly the computer itself.
i traded my obdI timing cover+ $20 for someones obdII cover, sensor, and reluctor wheel. not hard to find someone to trade with as popular as the obdI conversions are for the 96-97 guys
how hard was it...hmm, it was a PITA to figure out how to make the crank trigger work, but now that i know how, its quite easy, i can walk you through it, really not too bad, as long as your competent in wiring/soldering.
Old Apr 28, 2006 | 07:07 PM
  #26
LT1-TA's Avatar
well im going to buy the complete ready to go board cuz i hate soldering wires and never tried soldering on a board. And since this is going to run my baby im not going to learn on it. LoL.
So imma buy the stimulater and Complete board and wiring harness.
But since i already have a OBDII car, what will I do there on the ignition? And i will still be able to use my mallory box right?
Does MSII only watch the A/F ratio off one o2 sensor (random question i know. but jsut been reading and wondered)?
I have NO tuning experince at all.. i just know where my A/f ration needs to be generaly. But that is as deep as i know... so will i have a lot of probelms and a steep learning curve or what?
THanks for your help man... lol... at least i will be able to help others when i get this done a through with....
Old Apr 29, 2006 | 01:50 AM
  #27
firebird84's Avatar
the only problem you'll have is the MAF and all you need to get is a pro M maf and get a good tuner. its as simple as that nothing else needs to be said . thats it!
Old Apr 29, 2006 | 03:20 PM
  #28
Roadie's Avatar
There are ways to make the stock PCM read boost and work really well. I just chose to avoid the aggravation of splicing anything into the stock harness, like an accelleronics box, Pro-M MAF, etc. With a big turbo, I just decided to go with an aftermarket ECM to control everything.
I bought a FAST bank-to-bank ECM and a PCB Interface from White Racing and mounted it in place of the stock PCM (threw the stock PCM in a drawer in the garage).
The PCB interface allows you to totally get rid of the stock PCM. It's plug and play in that I didn't have to touch the stock wiring harness. I plugged the FAST into one side and the stock harness into the other. The only extra wiring added was for the programming cable and WB02 sensor -- a harness for that came with it. The PCB interface also controls all the stock gauges, including the speedo -- a set of dip switches are used for gear changes.
The best part about it was that I installed a FAST system in 15 minutes without cutting and splicing any wires.
I have a 6 speed, so I didn't have to worry about the transmission, but there are ways around the electronic auto transmissions as well.
Old Apr 29, 2006 | 07:02 PM
  #29
LT1-TA's Avatar
that is great an all.. i mean really.. that owuld totaly kick ***.. .
But with that you got to pay to play. MSII is cheap. Very cheap... and super versitale. I mean i pay $600 for everything (on the high side, but im buying everything pre-made) and I have full control. What is not to love about that?
BUt I think the learning curve is goin to be steep :-/
Old Apr 30, 2006 | 03:36 AM
  #30
5.0THIS's Avatar
So what did all of that cost? The FAST setup, the PCB interface, and the wideband setup to go with it...
