timing retard ... ?
Old Jun 4, 2004 | 02:16 PM
bowtiepwr's Avatar
Question timing retard ... ?
>now that the Camaro is running I need to know where to start with the retard dial (and I don't mean me either ) .
I have the MSD 6AL with boost timing master .
Isn't there a "general rule of thumb" with the amount of timing to pull with so much boost ?
Old Jun 4, 2004 | 02:32 PM
MEAN LT1's Avatar
Re: timing retard ... ?
Honestly I wouldnt even bother with the retard box. i would have it tuned on the dyno and add and decrease timing as needed. B/c supercharged boost goes up per rpm makes it alot easier to tune with.
Old Jun 4, 2004 | 08:38 PM
1st and goal's Avatar
I believe the maximum amount of timing it will pull is 15*
Set it to 2 and see how it goes and listen / watch for knock.
It will not hurt to have some race gas in it for inital testing just to be on the safe side.
Marc
Old Jun 5, 2004 | 03:55 AM
bowtiepwr's Avatar
Marc
>I will use this and start with 2 degrees , but I plan to go with the F.A.S.T. system .
Do you know if Dean sells and installs these ?
Sergio
Jan 27, 2016 04:27 PM
mikey4play
Mar 15, 2015 11:45 AM
nophix
Nov 30, 2014 10:26 PM
siguy
Nov 27, 2014 10:07 AM
