Those with Eagle Forged H-beams inside!
Old May 16, 2004 | 09:47 PM
  #16
engineermike's Avatar
The L19's (and maybe the 2000's) have larger heads than the 8740's. Sooooo, they must weigh more.
Mike
Old May 16, 2004 | 09:48 PM
  #17
Highlander's Avatar
Anyways I am not exactly sure which ones I have.. so I will have to check it out...
Any way to know?
Old May 16, 2004 | 10:13 PM
  #18
It's stamped into the bolt head.
Mike
Old May 16, 2004 | 10:16 PM
  #19
Highlander's Avatar
I found out... they are 8740s... so... they will be replaced... the reality is that I decided to remove the engine while jacking the car and for some reason it slipped to the PAN and it dented the pan a WHOLE LOT! so... now that the engine has NOTHING but the shortblock on the car.. I guess I have an excuse now to remove it and send the pistons to ceramic coat.. but I guess I will have to REBALANCE the whole rotating assembly.. I will weigh those rod bolts at school to check them out if they are the same weight or not.
Old Mar 11, 2006 | 03:18 PM
  #20
racer7088's Avatar
Thumbs up Re: Those with Eagle Forged H-beams inside!
The standard and huge 7/16 ARP 8740 bolts that come with the Eagle H-Beams are dramatic overkill and will not break probably ever unless you do something wrong. These are also run on the large big block chevy rods with great results too. On the small block stuff it's total overkill bt a little insurance too.
I've never had a rod bolt break on me in my life when tightening it!
Old Mar 11, 2006 | 06:17 PM
  #21
Acct 23749's Avatar
Wow
2 year old post brought back to life!
Old Mar 12, 2006 | 12:20 AM
  #22
racer7088's Avatar
Wow somehow it just got sent to me though! Sorry!
Old Mar 12, 2006 | 09:05 AM
  #23
Kevin Blown 95 TA's Avatar
It takes about 3 torqueings with the moly to get rid of the friction and obtain the right torque, or use the stretch gauge which is better in my opinion.
Some torque wrench experiences:
At work, we have a metrology department that has a Snap-On torque wrench tester. I checked my torque wrenches on it, and the Sears Craftsman ones were +-1# across the range which was a pleasant surprise, but the cheaper Made in Taiwan one that I use for wheel lugs was light by a 8-9# at 100# (I re-calibrated it). My Proto was dead on as was my dial recording one which I use on rear ends. The guys at the local speed shop who are machining my engine block gave me their expensive-as-hell Snap-On torque wrenches to check out. One was light by 3# at 50#, pretty close at 100#, and 3# heavy at 150#. The other was 3# heavy at 50#, 6# heavy at 100, and 9# heavy at 150#. These wrenches had been calibrated by Snap-On within the year.
Anyway, this is one reason that I am assemble my own shortblocks and using a stretch gauge on my rod bolts.
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
z28newbie
Sep 9, 2015 10:26 AM
