Thinking of Selling the LT1 Boost Shop Car kit
Old Oct 21, 2011 | 02:43 PM
RealQuick's Avatar
It is mild steel professionally coated, see pics here: (https://www.camaroz28.com/forums/sho...d.php?t=760740)
It works with stock K (as that is what I have on the shop car). I will include the Ohio Forced inductions Vertical radiator that fits without cutting anything! You can keep ABS, only delete A/C.
Here is a breakdown of the kit:
PTE76 GTS-H (ported housing) ... turbo has less than (less than 1000 miles on it) - new professionally coated housings
Custom Ceramic coated Hotparts AND DEI wrapped
1.75" headers
2.5" crossover
3" DP
50mm JGS wastegate
56mm JGS BOV
3" cold side professionally powdercoated black
4" A2A IC with support brackets
4 x 9 CAI Filter
4AN oil feed lines and 10AN drain
If someone ordered this kit thru me it would cost:
Standard Kit with TC76 - $5000
Upgrade from TC76 to PTE76GTS - $500
Wastegate Upgrade - $175
IC upgrade - $100
coated pipes (hot and cold) - $450
turbo housings coated - $150
DEI heat wrap - $150
Total = $6525 with all the upgrades.
I will sell for $5500 shipped to your door. I prefer not to split the kit up as the cold side is designed for this setup. I can take pics tonight of it installed.
This kit will support ~800rwhp, so it will be the last turbo kit you buy (unless you are looking for more power than that). Works with factory K & ABS, just need to delete A/C (by design).
Ignore the dirty engine bay!!
Old Oct 21, 2011 | 02:45 PM
RealQuick's Avatar
Re: Thinking of Selling the LT1 Boost Shop Car kit
Old Oct 24, 2011 | 07:39 PM
RealQuick's Avatar
Old Oct 24, 2011 | 07:42 PM
RealQuick's Avatar
Old Oct 25, 2011 | 11:49 AM
RealQuick's Avatar
Only thing used is the turbo (~1000 miles) and the IC (has ~5 miles).
I will also accept payments.
Old Oct 28, 2011 | 01:14 AM
97WS6SCharged's Avatar
Stop tempting me!
Old Oct 28, 2011 | 09:45 AM
RealQuick's Avatar
Come on Chris.... just do it already
The kit is much nicer in person though, the pics don't do it justice with such a dirty and cluttered engine bay.
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
YellowTransAm350
Mar 2, 2003 03:38 PM
