T Trim Pulley Combos
Old Feb 16, 2007 | 12:07 PM
97WS6SCharged's Avatar
Well, I'm getting ready to install my T trim onto my 383 and see what it can do. Before I do that, I need to order a crank pulley from ASP to match my ATI damper. Which size should I order? 7 or 8 inch? I already have enough blower pulleys to do either.
7"/2.75" combo
or
8"/3.2" combo
*Edit* 8 or 10 rib also? Thinking 8 would be ok for street, but not sure. Not sure where to find 10 rib belts either.
Old Feb 16, 2007 | 07:55 PM
engineermike's Avatar
I used a 6.66/2.75 combo on my aftercooled T-trim on a 383 with AFR 210's. It made 13 psi and ran 10.40 at 133 mph.
Mike
Old Feb 16, 2007 | 09:48 PM
Schurters LT1's Avatar
i don't think there is room for 8" crank ???? i have 7" crank & 2.65 6500 eng rpm 14lbs.....with my custom 4" piping
power in sig
Old Feb 17, 2007 | 08:38 AM
Guess I'll have to get under the nose and take some measurements.
Old Feb 18, 2007 | 01:54 PM
roguedriver's Avatar
power in sig
What Schurters said. An 8" won't fit cause it will come too close to the belt tensioner and also hit the passenger cooling fan motor. You may be able to squeeze a 7.25" in there. I'm running a 7"/2.75" 8 rib combo on my T. Works nicely. 14psi at 6k rpm. I would imagine it would make more at a lower altitude though.
Ken R.
Old Feb 22, 2007 | 05:49 PM
Ok, I went ahead and ordered the 7"/2.75" combo for the blower and ATI damper. I guess we'll see how they work in 4 weeks.
RUENUF
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
Hal Fisher
Sep 30, 2015 09:03 PM
cmsmith
Sep 14, 2015 09:25 PM
tdigger9899
Sep 7, 2015 10:56 AM
