Surging at low RPM/Light Throttle
Anyone else with a supercharged setup ever have any problems w/ surging at low rpm's with little or no throttle applied?
Car has Procharger setup, stock heads, 218/230 cam and forged 355 bottom end with speed pro blower pistons if this helps.
Thanks just wondering if someone has had a similar problem and can point me in the right direction.
Travis
Travis
Originally posted by Wild1
I've heard about that... I've heard two results:
1 - programming
2 - MAF location
1 - programming
2 - MAF location
Last night i ran a scan while it was at idle and the 02 mv's was under 50mv? Does that mean its running rich and trying to lean it out ?
Travis
The O2s should be bouncing between .100-.900 If they are stuck or lazy then they should be replaced. How are you testing your O2s? On a DVOM, if you have a Min/Max they should be near the extreme between .100-.900...
Low numbers are very lean.
Travis
Noenav
04-30-2015 01:06 PM
