superchargers and cam combo's
Re: superchargers and cam combo's
Originally posted by Liquidonyx
If i wanted to add a supercharger to my Lt-1 and run around 8 Lbs of boost what type of cam could I use?
thanks,
Aaron
thanks,
Aaron
Rich Krause
i have the 224/236 comp cam in my z28 with 8 pounds of boost .
and have to say it works really well.
you can see it at:
http://darcom.org
you can see it at:
http://darcom.org
Originally posted by Osmosis
Yea, search, but typically, you want a cam with a LC of 114. LPE has one specs out at .050 215/220 on 114 lc. I'm considering that one and the 211/219 on 112 lc
After 5200rpm... that cam just went free fall.`
I dissagree, I curretly have a zz3 cam and had it in my vett adn it was pretty good with the charger @ 10psi. I want to have a little larger cam with good streetability and idle quality. I ran low 12's in my Z with the zz3, afr heads and 8psi.
oldschool
Feb 9, 2016 09:21 PM
CARiD
Jan 27, 2015 06:27 AM
