Supercharger question -s-trim
Old Jul 11, 2004 | 10:12 PM
flusz28's Avatar
installing my kit i bought off a guy online. i need a oil feed plug- now vortech wants almost $50bucks for this. couldn't i just find some kind of fitting that will work just the same? also i'm going to run 8psi and have 42lbs injectors so i will need a fuel pressure regulator -correct? also i'n not sure exactly but what size pulley do i need for 8 psi.
Old Jul 12, 2004 | 03:47 PM
SMOKNZ's Avatar
You can use any fitting you want. On my last setup I picked up a steel Hex bushing (probably $2 from a hardware store) and welded that on the oil pan. It had 1/2 NPT threads on it and you can thread a multitude of things onto it: A brass hose barb, or pick up some AN fittings from Jegs. They actually have a nice weld on AN bung, which is what I got, for about $5. Pick up some fittings and hose and screw them together to make yourself a nice braided stainless steel hose. That would probably cost about $50!
You do not have to change the fuel press regulator for 42# injectors, just have to change the injector constant, and offsets in the PCM using Tunercat ot LT1 Edit.
No idea on pulley size... My boost doesn't use a pulley
Bill
Old Jul 12, 2004 | 08:33 PM
flusz28's Avatar
Hey - thanks for the reply - yeah i figured i could setup my own fitting stuff without buying the vortech one for $50 bucks..... yes i found out lastnight when i get my computer tuned and then dyno it they can change my fuel setting then- thanks - just need pulley size now.. hmm
Old Jul 12, 2004 | 11:15 PM
Highlander's Avatar
DO NOT USE ANYTHING OTHER THAN THE VORTECH!!!!!!!!!!!!!!!!!!!!!!!!!!
1st) its a long jet.. it will direct oil where it needs to be...
2nd) its a restrictor... you can kill your engine as i did with mine for lack of pressure because of the restrictor...
BUy the $59 peice... i have 2 right now for my 2 superchargers.
Old Jul 12, 2004 | 11:20 PM
flusz28's Avatar
hmm well i better not mess around then....
Old Jul 12, 2004 | 11:21 PM
Highlander's Avatar
I was like you till i saw the peice...
Old Jul 13, 2004 | 04:43 AM
SMOKNZ's Avatar
OH!!! I thought we were talking the oil DRAIN!!!! Sorry bud!
Bill
Old Jul 13, 2004 | 08:21 AM
flusz28's Avatar
thats okay
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
alex5366
Feb 17, 2015 09:07 AM
cyteone
Feb 7, 2015 06:04 PM
CARiD
Jan 27, 2015 06:27 AM
