supercharged lt1
Old Jan 5, 2005 | 04:50 AM
irocket87x's Avatar
supercharged lt1
I have a lt1 motor out of a 96 vette that i want to rebuilt, what should i do to the bottom end to hold up around +/- #12 of boost?
I also need to know what supercharger kit,injectors and fuelpump to go with
I prittymuch need to know what to do to this motor in order to make and hold up 400-500 whp motor lol.
im a noob at this so forgive anything i have said wrong....please help
Old Jan 5, 2005 | 05:22 AM
rskrause's Avatar
Moderator
Re: supercharged lt1
The biggest thing you can do to help the motor "live" with boost is to install a set of high quality, forged, low compression pistons. I have had good luck with JE, but there are other good brands as well. The rest of the rotating assy. can certainly also be upgraded but if you are contemplating this, don't forget the rest of the drivetrain. You will need a McLeod Street Twin clutch if you are using a T56 and if you are using sticky tires a new rear end and driveshaft. If you are using an automatic, upgrades will also be needed.
Rich
Old Jan 5, 2005 | 11:52 PM
OBE1 95Z28's Avatar
If you're going to run boost higher than 6 psi, you'll need an intercooler. I ran 9 psi without a cooler for awile and was seeing intake temperatures at 212 degrees
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
CARiD
Jan 27, 2015 06:27 AM
tubby
Oct 13, 2003 09:16 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
