STS turbo
Re: STS turbo
Call F-body Central in Baltimore, MD 410-242-0404 ask for Jason (owner). They've installed several and I've seen dyno #s in the 460rwhp range. Not much into turbos unless they're in a Buick, though. I have not seen any at the track...
--Alan
--Alan
Guest
Posts: n/a
Re: STS turbo
Originally Posted by BlackScreaminMachine
Only issues I have is they do at best 8 psi with meth injection..... it gives decent power for people who dont want it too wild, but for me its too mild.
Re: STS turbo
Look below and you will see my numbers. It has a safe tune and still running after almoset 2 years. Having a full Forged 383 engine built at this time with upgrading to a GT-67 turbo. Damit, got bit by the speed bug.
Re: STS turbo
Need I remind you of the 700rwhp sts car i rode in ...
They can be wild.
Re: STS turbo
I hear you can get away with a bit more boost with an STS because its rear mount gives it more time for the charged air to cool and the fact there may be some more pressure drop after traveling the distance back to the front although some say its no more than a front mount...but with a front mount IC you should be able to run more boost as well...kind of depends on where you are measuring the boost pressure....
Re: STS turbo
I dont like the idea of sticking a $2-3k turbo system under the rear of my car where it could get stolen while I sleep.. thats just me. If it werent for that seemingly major flaw(IMO) then it would be an awesome idea.
Re: STS turbo
Originally Posted by 1996z28m6
whats the difference between a turbo being under the rear and under the front? If someone wants it they will get it...a hood will not stop them.
Re: STS turbo
Originally Posted by jeepramz
So the high boost problem isn't the STS fault but high compression. I want to hear more about the 700 rwhp sts RealQuick.
He made 630rwhp @ 10psi and 700rwhp @ 14psi
