STS truck nets 669rwhp/744rwtq @ 9.5psi!!!
Re: STS truck nets 669rwhp/744rwtq @ 9.5psi!!!
Originally Posted by JZ 97 SS 1500
Well Mike just posted on the other site, 640 at 10psi. So the 700 must have been with 14psi. Also looks like he doesn't buy the truck #'s as well.
Jose
Jose
And your correct the 14psi was over 700 but was aborted when the head gasket let go
Mike, I'm curious about your headgasket problem. My customer that made over 700rwhp with his STS setup is now on his 2nd headgasket. I was thinking it was the piping is to restrictive causing the backpressure #'s to rise to over 4:1. I haven't proved it yet since I don't have his car here to do that with. He thinks its a limitation of the motor, but I assured him their are other LS1's making well over 700rwhp reliably. Are you still using the factory STS piping??
Jose
Jose
Jose
Jose
Yeah on his car he had to back the timing way down to keep it alive at the higher boost levels, but its costing him HP, though the turbo spools faster and the headers glow like candles..hehe
Jose
Jose
I have looked into EGTs which will coincide with the back pressure on the exhaust side, but haven't been able to get a pressure gauge on the exhaust yet. I am running 14psi in the low to mid 20's advance with plenty meth. I would suggest checking into those EGTs to give an idea about cylinder temp, which might help out on the warping problem.
RX Speed Works
Oct 1, 2015 10:19 PM
jackpawt883
Sep 10, 2015 08:53 PM
