stock lt1 shortblock and strim 6psi dyno within
Old Apr 8, 2004 | 01:08 PM
  #16
lt1ownsall's Avatar
Originally posted by EddieP
I take it those are the heads you bought off of George Hernandez in Austin (the 1st set that I ported for him)? What makes them so 'crappy'? Geo made some good numbers with them, and it sounds like you're not doing too bad either.
well besides a valve breaking and takeing my whole motor with it had about 700 miles on them when the valve broke
took my nice 4bolt my cam took a nice chip out of the heads
took everything but the intake
ill say crappy 2 pieace valves,
the exhaust ports need more work but other then that, they seem to love the boost
Old Apr 8, 2004 | 01:18 PM
  #17
EddieP's Avatar
Maybe I'm remembing things wrong, but wasn't the reason you bought the heads from Geo was because you broke a valve/messed up the motor? Did you break another one?
BTW, very nice numbers - glad it came together well.
Old Apr 8, 2004 | 01:47 PM
  #18
lt1ownsall's Avatar
no i bought the heads because i blew a head gasket and said why not, ill buy his.
his heads broke and took my motor
the machine shops said it was because of the cheap 2 pieace valves. he said they had stainless steel valves in them and they didnt. I still have half of the valve that broke.
but i have no bad faith towards him everything turned out for the better. just cost me an extra $1k
Old Apr 8, 2004 | 02:26 PM
  #19
EddieP's Avatar
Man, that's weird... I know Geo had his machine shop put new valves in them (they were supposed to be nice SS undercut valves).
Old Apr 8, 2004 | 02:52 PM
  #20
lt1ownsall's Avatar
yah, believe in geos honesty
they could of been ss valves but the were not 1 pieace
and they were not undercut
but anyhow the little heads do good
Old Apr 8, 2004 | 08:34 PM
  #21
EDS Z28's Avatar
Originally posted by RealQuick
I would love to hit 500rwhp with my combo:
Vortech S-Trim
LE Ported Heads
XE230/236 114LSA
LT's
48lb/hr's
The basic bolt-ons
You have a stock bottom end? Forget about 500 rwhp until you build it up. I made the numbers in my sig with a 2-bolt, stock crank, h-beam rods, trw pistons. Also, lower compression pistons are a must with a supercharger.
I pulled the procharger off, I am going to try the vortech v2/w the aftercooler. Basically looking for the same power or greater, but with very little noise. If I ever get board of that combo, going to bolt on a YS trim. I may end up using the ati twins again with the YS, who knows.
Old Apr 9, 2004 | 01:27 AM
  #22
josherSS's Avatar
why? the thread stater just did it
  #23
lt1ownsall's Avatar
the motor will or is makeing 500rwhp i got rid of the miss tonight
look at what it has according to all the foklord here on the board it shouldnt make half the hp
Old Apr 10, 2004 | 11:54 AM
  #24
Maldo's Avatar
hmmm
Old Apr 10, 2004 | 09:50 PM
  #25
EDS Z28's Avatar
It won't last for long at that power level, that's why. If you detonate one time, it'll all be over really quick.
Old Apr 11, 2004 | 05:36 PM
  #26
Highlander's Avatar
Damn you are making same power i did (501rwhp) with afr 190 heads no intercooler 224/236 XE 114 cam and a few tunning problems but at 8psi and a 383 on the bottom......
I say congrats.. what are your IATs? you are making some serious power for a non intercooled 350 with very mildly ported heads.. is this on pump gas???
You are gaining 200rwhp gain with only 6psi!! that is lsx 7L territory
Old Apr 11, 2004 | 08:59 PM
  #27
lt1ownsall's Avatar
my iat is not hooked up to my intake system
yes this is pump gas
i was makeing about 330 on the motor pre blower
i know one when i build my 355 i can get 600+ easy on pump gas
I just need some bigger injectors, my 38# are maxing out at 42 psi
Old Apr 11, 2004 | 09:02 PM
  #28
Highlander's Avatar
I should have made around 360 on motor alone more or less...
It took me a 6.66 crank and 2.85" pulley to achieve the 501rwhp... and 555rwhp with the aftercooler. You have a very efficient engine....
Old Apr 11, 2004 | 10:25 PM
  #29
lt1ownsall's Avatar
$200 shortblock came out of a cop car lol
Old Apr 11, 2004 | 10:49 PM
  #30
Highlander's Avatar
I have a cop car... Nothing special there
