Stock crank with 15psi??
Old Nov 4, 2006 | 04:22 PM
  #16
CrazyLT1's Avatar
sorry, meant to say 2 studs
Old Nov 4, 2006 | 04:23 PM
  #17
TransAm396's Avatar
2 bolt caps studded?
Old Nov 4, 2006 | 04:25 PM
  #18
CrazyLT1's Avatar
Yes
Old Nov 4, 2006 | 04:28 PM
  #19
TransAm396's Avatar
haha gotcha. But yes, like I said before..on a test block..with low power id feel much better blowing..well..not as bad..blowing a 2000$ block..as opposed to a fully built ***** to the walls 355..not to mention people making over 500rw bone stock..and only breaking pistons. I dont see why forged pistons/rods wouldnt be good enough to make all the power you could handle on the street.
Old Nov 4, 2006 | 04:39 PM
  #20
CrazyLT1's Avatar
I totally agree. It really also comes down to the tuning. The more budget you go, the less margin for error there is with the tuning. But I have also seen "all out forged" set-ups break under enough detonation just like anything else....
That said, stock set-ups can have also been proven to handle a lot with top notch tuning and no detonation
Old Nov 4, 2006 | 04:40 PM
  #21
TransAm396's Avatar
Yeap, I know a guy who had a turbo motor built spent 7k and it blew before the turbo made it to the car. Having the engine built and tuned right are way more important.
Old Nov 4, 2006 | 04:49 PM
  #22
cndctrdj's Avatar
Without converting to a 4 bolt splayed set up..?
never mind i found it
Old Nov 4, 2006 | 04:51 PM
  #23
TransAm396's Avatar
I think what he means is leaving in the 2 bolts allows you to keep more material in the block thus making it stronger....thats the first ive heard of it to. Where can you get stronger caps?
Old Nov 4, 2006 | 04:54 PM
  #24
detroit1994z28's Avatar
Re:
Yeah it kinda makes sense just to replace the stock crank since I already have the engine broke down. I'm just trying to save money cause I'm on a budget. But since I plan on running 15psi I should just replace the crank with a forged one. Cause I would hate to tear it down again if it were to go in the future. - Mike
Old Nov 4, 2006 | 06:35 PM
  #25
95 Z/28 LT1's Avatar
Super Moderator
There is no evidence that proves an aftermarket crank is any stronger than a stock crank. Me and a friend work on boosted LT1's all the time. NEVER seen a stock crank break. Have seen the crank "walk" a couple times on stock 2 bolt mains, but this was also around the 630 RWHP mark....but the crank itself was fine.....
Old Nov 4, 2006 | 06:55 PM
  #26
TransAm396's Avatar
Well if your on a budget where will this 15psi be coming from? IM guessing a supercharger?? Also, with that amount of boost...the word budget kinda goes out the window...can you give us some specs on what your doing?
Old Nov 4, 2006 | 07:00 PM
  #27
TransAm396's Avatar
Originally Posted by mgray
You can take a good stock crank way beyond factory power. Expect to spend the money to have it wet mag'd and the journals ground for a radius. Do not expect to get away with block work that is anything less than stellar. Cap walk would also be a means to the end. Even then, you would be flirting with longevity issues. The only reason I could see doing it is if you were ruled to do so. Then again, you could always do it for bragging rights.
yessir
Old Nov 4, 2006 | 07:04 PM
  #28
Yeah I had a sts turbo put on a couple years ago. I already upgraded everything there is such as the rear,fuel,etc,etc. Just not the motor yet. I just basically wanted to know if the stock crank could handle the 15psi. Cause I only plan on running 5psi most of the time and every so often have the high boost on the switch. So it's not like it's always running 15psi. But since I have the engine broke down I should replace everything with forged internals just incase I wanted to run more boost in the future. Which everyone knows you always get used to the power and want to run more in the future.
Old Nov 4, 2006 | 07:05 PM
  #29
TransAm396's Avatar
...what size turbo?
Old Nov 4, 2006 | 07:12 PM
  #30
It's the t-67 upgrade. Supposed to handle up to 750 at the fly. I'm basically just hoping to reach 600rwhp at 15psi. It might even reach that level at 12psi. But yeah if I were to use the stock crank it would not be more then 600rwhp
