Stock crank with 15psi??
If you only unleased the that much boost every once in a while, and as CrazyLT1 stated, if you have forged pistons and rods, then it might hold up for quite a while. There is a possiblity that it might not though. I think the odds are in your favor that it will last for a while, but you would still be taking a risk.
15psi coming from what?, what else is done to the motor? Heads/cam? Compression ratio? 15PSI from a 60-1 turbo might hold, but 15psi from a 91mm wouldnt.
Honestly, its alot more than 400. Thats why people dont do it. One of the biggest problems is the main caps. Without converting to a 4 bolt splayed set up..running a forged crank is useless. The caps still cant take that much power. And doing that is alot more. Figure a little over 500 for the crank, 200 for some decent caps, 100? for studs, and about 450 in machine work..thats about almost 1100$
I no the cost because i did it....is it really worth the money saved ??? I am making 15lbs of boost.....do you think i would trust a stock crank @686rwhp.....it could cost you everything in the end.......and that bill will be over the $1000 mark
Save your money and do it right the first time.....i took a full year off to do my car.....and that was the best thing i did .....
There is no evidence that proves an aftermarket crank is any stronger than a stock crank. Me and a friend work on boosted LT1's all the time. NEVER seen a stock crank break. Have seen the crank "walk" a couple times on stock 2 bolt mains, but this was also around the 630 RWHP mark....but the crank itself was fine.....
all that time and money into the shot block to save $400....
