Stall coverter
Old Mar 7, 2006 | 09:00 AM
michael_grayson's Avatar
Stall coverter
Say guys I was thinking about putting a stall in my 97 since I have to pull the tranny back to put in a new flexplate. It has a procharger on a stock motor with longtubes, exhaust and 58mm tb. What would be a good streetable stall for my car that is reasonably priced. I have a 388 stroker with afr heads for the near future.
Old Mar 7, 2006 | 09:26 AM
Cmr0z28's Avatar
Re: Stall coverter
You won't need an insanely large stall for a supercharged street car....I'd say 2800.
Old Mar 7, 2006 | 02:30 PM
LameRandomName's Avatar
Re: Stall coverter
A little pet peeve of mine...
It's not a "stall converter". ALL converters have a stall speed.
Also, you don't need a higher stall converter just because you have a powerful engine. In fact, you should use the lowest stall converter that get's the job done for the type of performance you are seeking.
Which is ... what?
Are you trying to tame a big cam or get a better launch at the dragstrip?
Do you understand the tradeoff you will be making in drivability, even with a quality piece from someone like Edge or Vigilante?
Old Mar 7, 2006 | 03:30 PM
engineermike's Avatar
Re: Stall coverter
That's funny 'cause my Vig 2800 flashes to 5400 rpm.
Mike
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
