SS progress pics
Old Jul 6, 2005 | 11:39 AM
  #16
96speed's Avatar
Re: SS progress pics
Originally Posted by slowpoke96z28
cool. i noticed the 9 inch and the stamped steel rear suspension components. what type of torque arm setup do you use? do you run into traction problems?
nice car
i still remember a young street warrior in GMHTP years ago.
Me too. GTP heads and a HOTcam or something? A little progress since then . Looks great. Some very trick pieces on your car. I like how it is outside of the box.
Ryan
Old Jul 7, 2005 | 12:56 AM
  #17
96SilverRam's Avatar
I always get a visual treat anytime you post pics of your beast. Glad to see you have really put so much attention to detail in your LT1. We are a dying breed Long live the the twin turbo LT1 and of course us N/A LT1 guys
Old Jul 7, 2005 | 04:45 PM
  #18
Schurters LT1's Avatar
How do you get the abs to work with the 9" rear?? i didn't think you could get the abs ring onto the gears in a 9"
Old Jul 7, 2005 | 06:31 PM
  #19
slp223's Avatar
just when i thought your car could not get any cooler. What K-member is that? when was your car in gmhtp?
Old Jul 7, 2005 | 06:36 PM
  #20
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
Thanks again guys.
slowpoke96z28- I use an old Spohn torque arm. (the slider version)
Traction is definitely a problem, but I'm ok with that. It did pull between 1.49-1.52 on the 27in hoosier QTP's last year. (but it had QA1 shocks at the time)
And yeah, I still streetrace a bit, it's pretty easy to take someone by suprise
Schurters LT1- Havn't tried it yet, but I think it should work. Reluctor wheel is from a 95 F150 (108 teeth, 106 is stock). Had to machine the ring to fit the differential (7.3in to fit the detroit true trac).
After that, I just had to measure where to drill the housing, and also dent the top of the housing down to get the sensor/reluctor clearance correct.
http://www.ls1speed.com/pictures/DSC02008.jpg
http://www.ls1speed.com/pictures/DSC02009.jpg
http://www.ls1speed.com/pictures/DSC02005.jpg
Old Jul 7, 2005 | 06:41 PM
  #21
JordonMusser's Avatar
West South Central Moderator / Special Guest
very nice dude, thats is very similar to how I had planned my TT setup. moving the motor mounts like that is the trick to making it work well.
Old Jul 8, 2005 | 04:00 PM
  #22
arnie's Avatar
Originally Posted by turbo_Z
Impressive!
In one of the pics it appears you are running dual fuel rails...
INTMD8, I take it, you are running saturated injectors?
Old Jul 10, 2005 | 05:19 PM
  #23
mrz28 73/97's Avatar
How are you able to keep ABS with the 9", I thought it wasn't possible, do you have 3 channel or 4 channel ABS? Absolutely great car, I hope to have someting like it one day.
Never mind I asked my question before looking at page 2, awesome to know I can put a 9" under the car and not have to lose ABS.
Old Jul 24, 2005 | 07:38 AM
  #24
BlueCamaroZ28's Avatar
Awesome.
Who makes those turbo headers?
Are you running stock PCM?
How is tuning done?
Is a 2 or 3 MAP sensor tuning possible on LT1's?
What other way to get it fueled and tuned, other than dual fuel rail/injectors, if you were to do it differently.
Old Jul 24, 2005 | 11:01 AM
  #25
INTMD8's Avatar
Originally Posted by BlueCamaroZ28
Awesome.
How is tuning done?
Thanks. I made the headers and turbo system.
The stock PCM is wired in with the Big Stuff3 (stand-alone engine management), so that the stock gauges, and A/C works. I also have it running the fans and fuel pump.
Tuning is done with the BS3, and is speed density.
I've heard of people using 2 bar map sensors with the stock PCM, but I have not done it. You would still need to use an impedence converter (which I do not like personally) to run a decent sized injector, and you would not have a closed loop wideband.
I previously had 1 set of injectors and a FAST system, which worked great, but I had to mix fuel in order to run higher boost.
Old Jul 24, 2005 | 05:04 PM
  #26
BruceVette's Avatar
here is another one. I am running 16 injectors 50s each. The first set 50s will operate at 80% duty cycle. The secondary injectors will kick in and is control by mega squirt via 4 bar map and wb02
http://www.pictureposter.allbrand.nu...nifold0002.jpg
http://www.pictureposter.allbrand.nu...tor+setup1.jpg
http://www.pictureposter.allbrand.nu...nifold0001.jpg
Old Jul 24, 2005 | 09:54 PM
  #27
MEAN LT1's Avatar
Wow, looks pretty uh........complex to say the least but cool none the less.
Old Jul 24, 2005 | 10:15 PM
  #28
unstable bob's Avatar
Talking Re: SS progress pics
Hey man...do the Space Shuttle dudes know that part is missing...
Friggin' badazz is all I can say!
Old Jul 24, 2005 | 10:18 PM
  #29
INTMD8's Avatar
Just curious why you would do that and not run dual fuel systems?
Old Jul 24, 2005 | 10:19 PM
  #30
Originally Posted by INTMD8
Just thought I would post a few pics of the progress of my car. Basically the same setup, except-
painted engine compartment/undercarriage
rebuilt engine/more head work, replaced rearend
BS3 with staged injection/dual fuel systems
tubular k-member, replaced suspension (mostly with 1LE pieces)
Replaced standard GT61's with ball bearing GT61's.
Clean and mean, dood...REAL CLEAN AND REAL MEAN! I love yer attention to detail! Just the sum of the parts are wicked, but the way you have everything "working together" is super max zoom wicked! You would get my vote on American Idol!
