Something nasty this way comes.... :)
http://fastbluetoys.com/Media/TurboP...omethingNasty/
getting close, only a few minor hurdles left, i.e. wiring the MSD, and injector converter.
can't wait
P
can't wait
P
Re: Something nasty this way comes.... :)
Originally Posted by Chrisbequick
What are you doing for a radiator?
-Chris
-Chris
-Chris
Stock radiator fits like a champ. This is the turbo kit off my car
http://www.fastblackcar.com/camaro/turbomotor/turboKitForT88/TimeToCleanTheEngineBay!!!/DSCF0018.JPG
I even had room for the ~3/8th thick turbine housing blanket.
I'd like to see some pics with the radiator in the car. My stock radiator wouldn't even come close to fitting with a turbo even smaller than that in the same location. I'd like to see what you're doing differently.
-Chris
-Chris
awesome looking regardless though
uhh.. I dont mean to sound like an ***, but did you look at the link I just posted :-D
A simple "check out the link" would have worked, too and wouldn't have made you sound like an ***.
Thanks for the pic!
-Chris
I can fit two T-76 turbos under my hood. It has GT-40's now but was mocked up with a T76. I have room for 2 more GT-40s if I need them
I really should update the picts on my site. A lot has changed since then. No more opti/coil wires everywhere. Engine compartment been painted.
machine-
its called careful design. The stock hood closes just fine (1/4" clearance). I might add I sitll had cruise/AC/PS and RUBBER engine mounts, and didnt have to move the radiator. But if you move the radiator you can open up a TON of room!
no compromises....
no compromises....
yes, wed like to see that!
