Solid or Hydrualic Turbo Setup
Old Feb 21, 2007 | 05:26 PM
93 4mula's Avatar
Would you run hydraulic or solid roller with a turbo setup to make 1000rwhp? And why? Trying to figure out if i need to or not
Old Feb 21, 2007 | 06:11 PM
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
For 1krwhp a hyd roller would be more than adequate. We have them running 7,500+rpm reliably, and have made 1,162rwhp with a hyd roller in a turbo LS1 car.
Old Feb 21, 2007 | 10:34 PM
93 4mula's Avatar
So I should be able to get the 1000rwhp mark with a hydraulic roller without a problem? Solid rollers a just a hassel to keep up with..
Old Feb 22, 2007 | 06:02 AM
rskrause's Avatar
Moderator
You could choose which you want, IOW it's optional. A second mortgage is mandatory.
Rich
Old Feb 22, 2007 | 07:22 AM
RealQuick's Avatar
Haha! aint that the truth!
Old Feb 22, 2007 | 07:12 PM
93 4mula's Avatar
Well i decided to go with a hydraulic roller cam for my turbo setup.. Does anyone know what the hp difference would be on a turbo setup with a hydrualic cam instead of a solid?
Old Feb 23, 2007 | 07:29 AM
engineermike's Avatar
I've heard people claim 50 hp difference when going from a hydraulic to a solid roller. However, I really believe that aggressive hydraulic lobes (Comp Extreme or XFI) with properly setup springs will perform as good as a solid.
Mike
Old Feb 23, 2007 | 07:31 AM
RealQuick's Avatar
Too many variables to just claim a hp # difference. Your next step should be concentrating on which hydraulic roller cam is best for your goals of 1000rwhp with te GT47-88.
Old Feb 23, 2007 | 11:04 AM
jaykar's Avatar
Exclamation HYD Rollers
The key to hyd rollers just like any valve train setup is
to keep the wieght out of the reciprocating or moving
parts of it, while making it strong enough to withstand
the RPM.
Lite wieght valves,titanium retainers,lite wieght rollers,
rockers, ect.
I run all of the above plus the AFR Hydra Rev setup.
I can pull strong thru 7200 but 6800 feels like the sweet
spot
Just my 2 centavos
Later
Irocing
Old Feb 25, 2007 | 03:16 PM
slomarao's Avatar
what kind of heads are you planning on running?
RUENUF
Mar 13, 2016 03:37 PM
FryedClutch
Sep 1, 2015 08:24 AM
bunker
Aug 1, 2015 10:10 PM
detroitmuscle
Jul 31, 2015 04:21 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
