Smoke when boosting?????????
Old Jul 31, 2005 | 07:18 PM
NZ12'S's Avatar
Engine just rebuilt runs great until I boost it, then it smokes like a train! Is it blowing oil past the rings on the non-firing pistons. I have a breather on the valve cover. Any thoughts please??
Old Jul 31, 2005 | 07:32 PM
aggiez28's Avatar
Re: Smoke when boosting?????????
dunno if anyone else see this or its just me but to me that sounds like a very "ricer" way of saying that its smoking when you are seeing boost.
brook
Old Jul 31, 2005 | 07:47 PM
SiDeWaYZz28's Avatar
did you brake in your motor before you threw your s/c on there??
you have to break in a new engine before it sees boost because the rings cant set properly
Old Aug 1, 2005 | 12:23 AM
MEAN LT1's Avatar
What color was the smoke?, I also agree with above. You have to let your rings at least seat before you start romping on her. Drive the car for 500-1000 miles and log it. Make sure there isnt anything in the oil when you change it. When you know the car is running pretty good then start getting on it and see what she does.
Old Aug 1, 2005 | 01:23 AM
breakmyfootoff's Avatar
Black Smoke = Fuel, running rich
White Smoke = Oil, probly due to excessive blow by if the rings aren't seated yet. Boost will exagerate the blowby if the rings aren't seated yet. Check the inlet on the blower to see if there is an excessive amount of oil there from the valve cover breather, if not than the oil is getting past the rings into the combustion chamber.
Old Aug 1, 2005 | 10:15 AM
OBE1 95Z28's Avatar
Black smoke = running rich
white smoke = coolant, possible blown head gasket
blue/grey smoke = oil
Old Aug 1, 2005 | 02:52 PM
NZ12'S's Avatar
Thanks for all the info. Yes it's blue smoke. You're probably right, the rings aren't seated good! We'll work on the break in some more, however it does have close to 7-8 hundred on it now I''m sure.
Old Aug 1, 2005 | 04:11 PM
SMOKNZ's Avatar
brook
No, it's just you...
Mikes 1994 z28
Oct 10, 2015 07:55 AM
greenzee28
Sep 25, 2015 04:29 PM
jackpawt883
Sep 10, 2015 08:53 PM
blaze309
Sep 8, 2015 05:27 PM
Henson071
Aug 4, 2015 09:32 AM
