Severe hesitation when transitioning from vacuum to boost (Stealth RT TT)
Old Feb 27, 2010 | 08:19 AM
CheshireCat's Avatar
I'm trying to help a friend diagnose a problem with his 1991 Dodge Stealth Twin Turbo. ( it is bone stock )
Car runs smooth when the gauge reads vacuum, but as soon as the needle gets to 0 or goes +boost, the car just falls on its face. It does this in any gear at any rpm...
My gut tells me that it's a bad sensor, or a vacuum/boost leak. I've never owned a turbo car, so i figured I'd ask here.
Any suggestions of things we should check?
Old Feb 27, 2010 | 05:19 PM
jay_rich's Avatar
im gonna go with a big boost leak, I know my car I got on it once and I forgot to tighten my throttle body coupler and it popped of and the car fell dead.
Jay
Old Feb 28, 2010 | 08:19 AM
Thanks for the suggestion. I think we'll try to track down any boost leaks first. With twin turbos and air to air intercoolers, there's a lot of pipe and couplers to check...
Old Feb 28, 2010 | 12:37 PM
jay_rich's Avatar
do those cars have maf's? that was why mine shut down bc the engine was sucking in air and the maf was reading it.
Jay
Old Feb 28, 2010 | 01:45 PM
blown94's Avatar
Are you seeing any boost on the gauge or dont u have one hooked up? If not get a cheap one from autozone and hook it into a vac line somewhere so you can measure it. Im gonna guess like the rest of these guys that you have a boost leak somewhere and its dumping when under boost and overfueling.
Old Feb 28, 2010 | 05:42 PM
RealQuick's Avatar
Without a boost gauge or A/F, it will be tough to diagnose.
Old Mar 1, 2010 | 02:53 PM
Sparkz28ss's Avatar
Boost leaks or maybe a bad FPR if its falling on its face from the transition from vac to boost
check out www.3si.org
Old Mar 1, 2010 | 07:37 PM
The car does have a vac/boost gauge and it does indicate positive boost. Just as soon as the boost gauge reaches 0 and goes positive, it just runs like a dog and falls on it's face. It doesn't stall out though.
Unfortunately we don't have a A/F gauge...
Before posting here I did some searching on 3si.org and socal3s.com... Thanks for the advice all!
Old Mar 2, 2010 | 01:14 PM
97WS6SCharged's Avatar
Sounds like you need to get it on a scanner of some sorts and see what the computer is seeing when you get on it.
KYWes
Jun 14, 2022 06:52 AM
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
zk06
Sep 9, 2015 11:39 AM
350350
14
Aug 11, 2015 12:03 PM
Henson071
Aug 4, 2015 09:32 AM
