Severe hesitation when transitioning from vacuum to boost (Stealth RT TT)
I'm trying to help a friend diagnose a problem with his 1991 Dodge Stealth Twin Turbo. ( it is bone stock )
Car runs smooth when the gauge reads vacuum, but as soon as the needle gets to 0 or goes +boost, the car just falls on its face. It does this in any gear at any rpm...
My gut tells me that it's a bad sensor, or a vacuum/boost leak. I've never owned a turbo car, so i figured I'd ask here.
Any suggestions of things we should check?
Are you seeing any boost on the gauge or dont u have one hooked up? If not get a cheap one from autozone and hook it into a vac line somewhere so you can measure it. Im gonna guess like the rest of these guys that you have a boost leak somewhere and its dumping when under boost and overfueling.
Boost leaks or maybe a bad FPR if its falling on its face from the transition from vac to boost
check out www.3si.org
Unfortunately we don't have a A/F gauge...
14
Aug 11, 2015 12:03 PM
Henson071
Aug 4, 2015 09:32 AM
